It is currently Tue May 05, 2026 2:50 am
 Post subject: cam question
PostPosted: Mon Feb 20, 2012 12:20 am
im thinking of changing mine in the future and just planing ahead right now im running a 110 and thinking about the vz15 how are they
 Post subject: Re: cam question
PostPosted: Mon Feb 20, 2012 12:43 am
I don't know what size motor u run but if I was taking out a 110 and u wanted to run a little more top end I would try a FK44 with 1.4 rockers
PostPosted: Mon Feb 20, 2012 12:51 am
2221 and no not looking for more top end if anything a little more bottom and i was gonna go with the 1.25 rockers
PostPosted: Mon Feb 20, 2012 1:13 am
Don't think the vz15 will give u more low end, the 110 is a very good low end cam at 247 @ .050
PostPosted: Mon Feb 20, 2012 1:16 am
my motor runs and dose great im just wanting to do something new i always had 110 cams i just heard a vz will turn on real good im open to any suggestions i wanna change heads cam rockers i have o44 heads right now wanna go bigger and 110 cam and stock rockers
PostPosted: Mon Feb 20, 2012 1:23 am
Have u tryed ratio rockers with the 110 ?
PostPosted: Mon Feb 20, 2012 1:25 am
i have not tried anything im not knowledgeable about what is good with what lol
PostPosted: Mon Feb 20, 2012 1:38 am
I would try a set of ratio rockers . U may have just what u want
PostPosted: Mon Feb 20, 2012 9:04 pm
X2 I ran a 110 and 1.25 in a 1915 put a vz 15 and 1.1 run it for a year and put the 110 and 1.25 back in . If you are look for a cam to try i would look at FK 42 and 1.4 rocker and port the 044 heads .
PostPosted: Mon Feb 20, 2012 9:08 pm
whatever cam u decide on prob would want to go with cb performance adjustable straight cut gears...sweet set for the price....im running 110 with ratios....also 1 1/2 exhaust for more bottom end
