 Post subject: 2332
PostPosted: Fri Feb 17, 2012 10:03 pm
I just bought a 2332 with 041 heads and duel empi 44 i was wondering what kind of horsepower and torqe it would put out i don't know the kind of cam?
 Post subject: Re: 2332
PostPosted: Fri Feb 17, 2012 10:10 pm
40 to 180 cam & port work - rockers -compression -tuning . OK 40 is a little low 100
PostPosted: Fri Feb 17, 2012 10:15 pm
Racebuggys 2332 11.1 port heads s/e 44 carbs fk44 cam 1.4 rocker Dyno at 165hp 5500rpm 170tq 4000 i think
PostPosted: Fri Feb 17, 2012 10:17 pm
i think it has 1.25 rockers all i know about the heads is that he said 041 with big valves
PostPosted: Fri Feb 17, 2012 10:20 pm
Build TQ
PostPosted: Fri Feb 17, 2012 10:23 pm
Pump gas or race gas . do's it run good
PostPosted: Fri Feb 17, 2012 10:35 pm
iam going to run 93 pump gas and yes it ran iam having it put in my buggy right now
PostPosted: Fri Feb 17, 2012 10:51 pm
125-140 ?
PostPosted: Sat Feb 25, 2012 1:08 pm
i found out what kind of cam is in that motor it is a 125 are they any good for hill climbing and woods riding the tranny i got is a 6 rib mid shift with 4.83 r&p how well do you all think is will work
PostPosted: Sat Feb 25, 2012 1:34 pm
Run it and see. w125 will work go mid-hi rpms 4000-6500.
PostPosted: Sat Feb 25, 2012 1:40 pm
ok will i have to use the clutch alot to keep the rpms up or will it lug alittle
PostPosted: Sat Feb 25, 2012 2:34 pm
I run a engle 120 on a 2275 with a single Carb and I love it. You may lose some bottom end with the dual carbs but not a whole lot I would think. I bet horsepower is at least 130-150 with your setup. The only way to know if you will like its performance is run it.
PostPosted: Sat Feb 25, 2012 3:07 pm
ok thx for the help it is getting put together right now i just started searching about the 125 cam and i got kind of worried it would be to much for woods riding but i will try it out and see how i like it i just don't want to have to keep hitting the clutch all the time to keep it from bogging out on me
PostPosted: Sat Feb 25, 2012 5:05 pm
as long as you have the rpm up when you hit it ,you should be good! hold it to the floor and dont let off! :twisted:
PostPosted: Sun Feb 26, 2012 12:16 pm
Talk to buggiejunky his runing a cam reel close. If the buggy is geard low it will work good.
