It is currently Sun May 03, 2026 6:46 pm
PostPosted: Mon Jan 23, 2012 5:44 pm
Ok so one of my buddys bought a long block the other day, and we was actually putting it back together today and we noticed that it didnt have anywere to put a fuel pump on it, it was'nt cut out for nothing to go on it, Is anybodys block set up like this? If so what do you do for it? Thanks
PostPosted: Mon Jan 23, 2012 5:54 pm
You've got a fuel injection vw block, use electric pump.
PostPosted: Mon Jan 23, 2012 6:17 pm
X2, some say that the fuel injection blocks are stronger.Chad :mrgreen:
PostPosted: Mon Jan 23, 2012 7:13 pm
it,s prob. as-21 block elect. pump
PostPosted: Mon Jan 23, 2012 8:42 pm
aj block fuel inj get pump with 3pounds if you run bigger pump use regulator 3pounds
PostPosted: Mon Jan 23, 2012 9:42 pm
Old school guys said the fuel injected motors had more desirable cams in them than carb motors.
PostPosted: Tue Jan 24, 2012 12:06 pm
Allright guys thanks for the help!
