| best valve train for 1915??? http://woodsbuggy.com/phpBB3/viewtopic.php?f=3&t=12931 |
| Author: | rip-it [ Tue Jan 10, 2012 7:55 am ] |
| Post subject: | best valve train for 1915??? |
I currently run a 2165 with dual Idf 40”s and a 6 rib. Just picked up an engine for parts and found out it’s a 1915 with 041 Mofoco heads (not ported)….Surprise!!! |
| Author: | rip-it [ Tue Jan 10, 2012 3:37 pm ] |
| Post subject: | Re: best valve train for 1915??? |
106 views????? Does anybody have at least an opinion? |
| Author: | pipedope [ Tue Jan 10, 2012 6:29 pm ] |
110 cam and 1.25 rockers and make sure you use a 5 rib tranny great combination |
| Author: | hyde [ Tue Jan 10, 2012 8:15 pm ] |
X2 w110 or c35 1.25 scat racing rockers and dual valve springs chromoly retainers . or a fk 41or42 and 1.4 rocker will work good .or vz 14 and 1.1 rockers The fks 41&42 are short duration but hi lift .510 to.522 with ported heads should make alot of TQ and mid-range power . Comperssion will help the TQ alot . Pump gas 93 octane 9.5to1 50/50 race gas pump gas 10.5 to1 100% race gas 11 and up |
| Author: | wrongwayray [ Tue Jan 10, 2012 8:55 pm ] |
Ive got the mini wedgeports 1.25 rockers intakes matched 9 to 1 pump gas. Runs swell taken out plenty bigger motors. My buddies will confirm. Fun motor. . On cb performance go to builders choice engine kits. Pretty cool |
| Author: | rip-it [ Wed Jan 11, 2012 8:07 am ] |
Thank you: pipedope, wrongwayray, hyde I’m pretty sure it’s going to end up with a 110 cam, 1.25 rockers and 9.5:1 |
| Author: | AB250r [ Wed Jan 11, 2012 4:35 pm ] |
I run c45 and scat 1.25 rockers with 5 rib super diff! I do run vp 110! |
| Author: | Maddog [ Wed Jan 11, 2012 6:55 pm ] |
Engle fk7 with 1.4 rocker on my 1914 Excellent torque and rpm |
| Author: | reno2165 [ Wed Jan 11, 2012 7:45 pm ] |
i also run a 2165,110 cam, got dual 40 dellortos with 2BR VW heads (40x35.5 valves), had em fly cut with 11.1 comp. got all the other go fast goodies except the ratio rockers...have thought about getting them but would it make that big a difference with my set up??? (483 trans, 38 buckshots) |
| Author: | reno2165 [ Wed Jan 11, 2012 7:48 pm ] |
..1.25, 1.3, or 1.4s??? |
| Author: | reno2165 [ Wed Jan 11, 2012 7:52 pm ] |
is it a difference through the entire RPM range or more of a bottom or top end gain??? |
| Author: | Maddog [ Wed Jan 11, 2012 8:08 pm ] |
Depends on cam, the fk7 was designed for 1.4 rockers. I chose it due to lower duration 288 and higher lift 0.50, I wanted a cam that would bring in the torque at lower rpm but still turn up,comes on strong about 2600 rpm. Nice powerband. Pulls to 6300. Higher duration cams are for high rpms and they cost you low end torque. A 110 cam with 1.25 rockers duration 284 lift .491 |
| Author: | Aaron Creech [ Wed Jan 11, 2012 8:13 pm ] |
I would go no more than 1.25 rockers on a 110 cam. More lift will give more low end torque because of better cylinder filling capabilities at lower RPM. I know alot of people will argue,but 11:1 is WAY too much compression for a 110 cam or any cam with duration that low. |
| Author: | hyde [ Wed Jan 11, 2012 8:15 pm ] |
reno2165 wrote: is it a difference through the entire RPM range or more of a bottom or top end gain??? When you us ratio rockers you ad lift and a litte duration. Most of the time it helps the entire RPM range you will need dual valve springs and chromoly retainers . |
| Author: | hyde [ Wed Jan 11, 2012 8:20 pm ] |
Maddog wrote: Depends on cam, the fk7 was designed for 1.4 rockers. I chose it due to lower duration 288 and higher lift 0.50, I wanted a cam that would bring in the torque at lower rpm but still turn up,comes on strong about 2600 rpm. Nice powerband. Pulls to 6300. Higher duration cams are for high rpms and they cost you low end torque. A 110 cam with 1.25 rockers duration 284 lift .491 I would like to try a fk41 ad duration 269 .050 239 and .510 lift with 1.4 |
| Author: | Maddog [ Wed Jan 11, 2012 8:35 pm ] |
hyde wrote: Maddog wrote: Depends on cam, the fk7 was designed for 1.4 rockers. I chose it due to lower duration 288 and higher lift 0.50, I wanted a cam that would bring in the torque at lower rpm but still turn up,comes on strong about 2600 rpm. Nice powerband. Pulls to 6300. Higher duration cams are for high rpms and they cost you low end torque. A 110 cam with 1.25 rockers duration 284 lift .491 I would like to try a fk41 ad duration 269 .050 239 and .510 lift with 1.4 I think I might have a new favorite cam fk41. That's the lowest duration I ever seen for a cam with that much lift. Jake Raby has the dyno for it here http://forums.aircooledtechnology.com/s ... php?t=4539 I'm gonna look hard at that one for the next engine. |
| Author: | reno2165 [ Wed Jan 11, 2012 8:42 pm ] |
is 11:1 too much? this is the first motor ive built and it does what i ask, jus lookin for a lil more..ive learned alot since it was put together and probably would have done it different..its a good topic and looking for opinions |
| Author: | hyde [ Wed Jan 11, 2012 8:49 pm ] |
reno2165 wrote: is 11:1 too much? this is the first motor ive built and it does what i ask, jus lookin for a lil more..ive learned alot since it was put together and probably would have done it different..its a good topic and looking for opinions Compression will help make TQ .Just run race gas |
| Author: | reno2165 [ Wed Jan 11, 2012 8:53 pm ] |
all she drinks is the blue fast gas.. |
| Author: | hyde [ Wed Jan 11, 2012 8:54 pm ] |
Maddog wrote: hyde wrote: Maddog wrote: Depends on cam, the fk7 was designed for 1.4 rockers. I chose it due to lower duration 288 and higher lift 0.50, I wanted a cam that would bring in the torque at lower rpm but still turn up,comes on strong about 2600 rpm. Nice powerband. Pulls to 6300. Higher duration cams are for high rpms and they cost you low end torque. A 110 cam with 1.25 rockers duration 284 lift .491 I would like to try a fk41 ad duration 269 .050 239 and .510 lift with 1.4 I think I might have a new favorite cam fk41. That's the lowest duration I ever seen for a cam with that much lift. Jake Raby has the dyno for it here http://forums.aircooledtechnology.com/s ... php?t=4539 I'm gonna look hard at that one for the next engine. With some ported heads it would go up in RPMs a litte more |
| Author: | Aaron Creech [ Wed Jan 11, 2012 9:19 pm ] |
reno2165 wrote: is 11:1 too much? this is the first motor ive built and it does what i ask, jus lookin for a lil more..ive learned alot since it was put together and probably would have done it different..its a good topic and looking for opinions I'm sure it runs just fine. As Hyde stated, higher comp gives more torque. An engine with hi compression can utilize more cam duration and still retain great torque numbers along with running cooler and being overall more efficient. A camshaft should be the very last piece of any engine build so it can be matched to the rest of the components for a great overall package. |
| Author: | rip-it [ Thu Jan 12, 2012 8:06 am ] |
Thanks guys, good info!! |
