| adding a oil temp gauge? http://woodsbuggy.com/phpBB3/viewtopic.php?f=3&t=12865 |
| Author: | ridenrace6 [ Fri Dec 30, 2011 5:58 am ] |
| Post subject: | adding a oil temp gauge? |
whats the best way and place to add/pumb in a oil temp sender without restricting oil flow ? i thought about adding a "port" midway of the dry sump tank but was afraid some aluminum shavings would get in the bottom of the tank that i couldnt or might not get out |
| Author: | gasman [ Fri Dec 30, 2011 8:38 am ] |
| Post subject: | Re: adding a oil temp gauge? |
Put a tee where your oil pressure sending unit goes in the block,I'd think you would want a temp gauge closer to the block than the tank to get a good read on oil temp in engine.Chad |
| Author: | rip-it [ Fri Dec 30, 2011 9:25 am ] |
I put a "T" on the OUT line to the cooler. The thermal coupler only sticks into the passing line a 1/4". Running that way for 3yr. |
