| pushrod tubes & seals http://woodsbuggy.com/phpBB3/viewtopic.php?f=3&t=12863 |
Page 1 of 2 |
| Author: | ridenrace6 [ Fri Dec 30, 2011 5:12 am ] |
| Post subject: | pushrod tubes & seals |
which are the best ones, spring loaded or crush type, also there are different brands and types of each one so specific reomendations are greatly apprecciated? |
| Author: | Rick [ Fri Dec 30, 2011 9:02 am ] |
| Post subject: | Re: pushrod tubes & seals |
Kybuggy turned me on to these when i bent a stock tube. They a awesome tubes...www.jayceevw.com/products work great and never leak a drop |
| Author: | gasman [ Fri Dec 30, 2011 9:08 am ] |
I've ran a bunch of different tubes from stock to high dollar threaded aluminum ones,and I've found (for me) the bug pack presto tubes do just fine,and I prefer the seals to be from the cheap gasket sets the red ones,have to go look at brand just know by seeing the package.a lot complain about them leaking but I don't have that much problem,the few that did leak I streched the spring a liitle if it wouldn't stop after twisting them a little,and it a lot easier to change one out if this happens.but everybody should at least have two of these in there tool kit if they run the steal factory ones.never know when a big flop stick or something will make it's way up in there and bend or tear one out,and with the presto tubes you fix it with out pulling the head.Chad |
| Author: | ridenrace6 [ Sun Jan 01, 2012 2:14 am ] |
only 3 of us run pushrod tubes |
| Author: | Aaron Creech [ Sun Jan 01, 2012 8:47 pm ] |
The Jay Cee tubes are very nice and have plenty of room for the pushrods when using hi ratio rockers. I have used several sets and never had one leak. Stock style tubes are great as well but not as easy to repair if one gets damaged. |
| Author: | hyde [ Sun Jan 01, 2012 9:30 pm ] |
Aaron Creech wrote: The Jay Cee tubes are very nice and have plenty of room for the pushrods when using hi ratio rockers. I have used several sets and never had one leak. Stock style tubes are great as well but not as easy to repair if one gets damaged. I like the stock type windage or big ends windage . I use spring loaded scats or jay cee for repairs . |
| Author: | ron [ Mon Jan 02, 2012 12:31 pm ] |
jay cee push rod tubes are all i have ran for the last five years or so , there a little pricey but well worth it , you can get them in about 10 different colors at c.b. performance & several other places !! you can install your heads before you install the tubes , easier to start your torque sequence !! c.b. part # 1517 is probably what your looking for ( they are red & blue ) , they also have red too !!!! |
| Author: | perrib [ Mon Jan 02, 2012 6:34 pm ] |
I have JCs on my race engine. Most of the time I just us stock ones. Bugpack and Scat have a decent copy of the JCs. The Jcs have a larger opening so the pushrod won't hit the tube. |
| Author: | ridenrace6 [ Mon Jan 02, 2012 11:45 pm ] |
RON wrote: c.b. part # 1517 is probably what your looking for ( they are red & blue ) what makes you think i want red and blue |
| Author: | ron [ Tue Jan 03, 2012 8:07 am ] |
ridenrace6 wrote: RON wrote: c.b. part # 1517 is probably what your looking for ( they are red & blue ) what makes you think i want red and blue just a lucky guess ! |
| Author: | JeffClay [ Tue Jan 03, 2012 10:36 am ] |
you guys dont run pushrod tubes? |
| Author: | ridenrace6 [ Wed Jan 04, 2012 6:53 am ] |
can somebody tell me if there is difference in these other than the price http://www.pacificcustoms.com/mm5/merch ... ange_high= & http://www.cbperformance.com/catalog.asp?ProductID=1395 also a buddy of mine got a set of these the other day and they have a 3rd seal that goes in the center http://www.pacificcustoms.com/mm5/merch ... ange_high= |
| Author: | ridenrace6 [ Wed Jan 04, 2012 6:58 am ] |
JeffClay wrote: you guys dont run pushrod tubes? evidently only a few of do, the rest must have went wc or prefabbed |
| Author: | Rick [ Wed Jan 04, 2012 8:31 am ] |
get the jaycee and be done $90.00 is the going rate.. those cheaper ones are probably OK but when you see the jaycees you will think yourself |
| Author: | ron [ Wed Jan 04, 2012 3:40 pm ] |
the first two are the same , the third one is a weaker knock-off of jay cee ( a wanna be ) , yhe reason c.b. is cheaper is they buy in bulk , if you go to moores or other vendors that sell c.b. parts they are higher than dealing directly with c.b. ( call marie ann at c.b. ) and get them there !! |
| Author: | kevin f [ Wed Jan 04, 2012 10:33 pm ] |
All i use are the stock style windage tubes. They work great as long as you dont run huge ratio rockers. So chris these wont work for you. |
| Author: | ridenrace6 [ Thu Jan 05, 2012 2:56 am ] |
whats the deal on the red and white seals, is one color better than the other????? |
| Author: | ridenrace6 [ Thu Jan 05, 2012 2:59 am ] |
kevin f wrote: All i use are the stock style windage tubes. They work great as long as you dont run huge ratio rockers. So chris these wont work for you. so those wont work on a 1.25 rocker |
| Author: | ron [ Thu Jan 05, 2012 10:44 am ] |
ridenrace6 wrote: whats the deal on the red and white seals, is one color better than the other????? i've used both , the red ones was actually the color of the original german gasket makers of yester year , i've got them at a local supply house before ???? , so they are still in circulation , as for which is better i do'nt really know , the red ones seem to have more density than the white ones !! the white ones are in most gasket sets you purchase now at places like c.b. ,moores & veedub parts unlimited !! |
| Author: | kevin f [ Thu Jan 05, 2012 11:29 am ] |
ridenrace6 wrote: kevin f wrote: All i use are the stock style windage tubes. They work great as long as you dont run huge ratio rockers. So chris these wont work for you. so those wont work on a 1.25 rocker yea they will work with 1.25 but no bigger. I had to take a screw driver and swedge the end on the head open a little so the push rod wouldnt rub it. |
| Author: | Baddvw [ Thu Jan 05, 2012 2:04 pm ] |
Jaycee all the way......buy the best, cry only once.... |
| Author: | ron [ Thu Jan 05, 2012 2:52 pm ] |
Baddvw wrote: Jaycee all the way......buy the best, cry only once.... well said , my brother !! |
| Author: | ridenrace6 [ Fri Jan 13, 2012 4:42 am ] |
well i ordered some jaycee from cb performance that should be here monday but i'm wandering how many people use silicone around the seals, ive always used the windage stock type tubes before and no silicone and never had a leaking problem but the spring loaded ones i just took off this motor had silicone so do i use silisone on the end seals or not???????? |
| Author: | davehix [ Fri Jan 13, 2012 5:05 am ] |
I never use sealant on my pushrod tubes I would say no.that would be my opinion ridenrace6 wrote: well i ordered some jaycee from cb performance that should be here monday but i'm wandering how many people use silicone around the seals, ive always used the windage stock type tubes before and no silicone and never had a leaking problem but the spring loaded ones i just took off this motor had silicone
| Author: | gasman [ Fri Jan 13, 2012 10:29 am ] |
davehix wrote: I never use sealant on my pushrod tubes I would say no.that would be my opinion ridenrace6 wrote: well i ordered some jaycee from cb performance that should be here monday but i'm wandering how many people use silicone around the seals, ive always used the windage stock type tubes before and no silicone and never had a leaking problem but the spring loaded ones i just took off this motor had silicone so do i use silisone on the end seals or not???????? X2 I would not use any.Chad |
