It is currently Mon May 04, 2026 4:33 am
 Post subject: Block
PostPosted: Sat Sep 22, 2007 7:29 pm
Does anyone konow anything thing about and AJ block vw book says 1974 modle block it has no fuel pump mount .I have never used one was thinking of using for a 1915 . I have only used AH and AE thank
PostPosted: Sun Sep 23, 2007 6:58 am
Any case that has no fuel pump opening is from a fuel injected bug. They are supposed to be the strongest cases to use. I believe they are an AS-21 number and they had changed the alloy a little bit to make them stronger. I have used them with very good results.
Go ahead and run it. You will be fine.
PostPosted: Sun Sep 23, 2007 8:15 am
Thanks Roy
