It is currently Mon May 04, 2026 1:54 am
 Post subject: 2500 Question
PostPosted: Wed Nov 09, 2011 1:10 am
Planning a future buggy in my head. Curious what a strong running 2500 Actually puts out HP and Torque wise. Trying to see what I need for a strong heavy duty buggy to still be in the power to weight ratio.
 Post subject: Re: 2500 Question
PostPosted: Wed Nov 09, 2011 10:26 am
The HP and torque all depends on the heads and cam combination, there is always more HP then torque in the VW A/C world, I would guess mine is around 200HP and 185 ft.lbs. torque?? I dunno, but it pulls my somewhat heavy buggy with me (285lbs.) in it very well with a 3.10 first gear lugging it very low rpm speed around in the woods and sometimes superlow rpm in 2nd gear (2.36), I would say that every bit of my buggy is in the 1500-1600 lbs range and then add me to it to make it almost 1900lbs. at the most guesstimate weight total :| :|
Anyhow, if I want a high-revving VW motor and still puts out very respected torque by my choice would be a 2332 with big heads and a good mid-high range cam (4500-8500 rpm) but the downfall would be is you will have to have a featherweight buggy for the motor to be able to lug it around very well because of the big heads and monster cam, that combo is known not to have hardly any bottom end torque at all. The dollar for dollar on the 2500 topped off with a set of 44idf's, a pretty mild set of heads (modded Street Eliminators) and a decent cam (w-110) tuned in properly does great IMO versus the 2332 with a set of 48ifd's, Superflow big valve heads with a monster cam (example----fk-87, fk-89) would be pretty close, but the 2500 may be a bit more $$$ depending on how wild you want to go. I have always had the rev limiter set on 7,000 rpm and was told it kicked in a couple of times and it is fast as hell, I put in a 6,000 rpm in it now since I changed the box just to see if I really need the extra 1,000 rpm, so far, I did'nt need it.
PostPosted: Wed Nov 09, 2011 10:48 am
Thanks chad, and for the record I won't be going air cooled. Just trying to see what kind of power to weight ratios the light single seaters are running. I like the way they perform but wont own a single seater unless I get devorced. Just want to know what kind of power I need in a heavier buggy to be similer. Then I can start loking at engine trans combos to see what works.
PostPosted: Wed Nov 09, 2011 8:39 pm
I have dyno some VW. Drews woods bugg eng 2387 fk cam s\e heads 44 carbs 190tq 170 hp on Sattlers dts water brake . Same eng. at Drews made 175 tq . Nitro you need s\c and trans
PostPosted: Wed Nov 09, 2011 8:50 pm
Exactly what I am thinking Hyde. 200lbs more on a 2000 lb buggy is only 10%. As long as power to weight, gearing, traction and balance are close it will be good enough for me.
