| Engine ID Codes http://woodsbuggy.com/phpBB3/viewtopic.php?f=3&t=12486 |
| Author: | Wart Hog [ Sun Oct 23, 2011 11:47 am ] |
| Post subject: | Engine ID Codes |
I was trying to find out what engine I have on my buggy and came across this: Engine ID Codes VW stamped all type 1's and pre '72 type 2's on the right case half just below the generator pedestal. The first and sometimes the second digit/letter denotes the basic engine group. So the best you can do is narrow down the engine to a group. Here are the groups Type 1 Code Year Engine Remarks 4 - 60 - 1200 - 40 HP 5 - 61 - 1200 - 40 HP 6 - 62 - 1200 - 40 HP 7 - 63 - 1200 - 40 HP 8 - 64 - 1200 - 40 HP 9 - 65 - 1200 - 40 HP FO - 66 - 1300 - 8mm oil pump studs HO/TO- 67 - 1500 - 8mm oil pump studs H5 - 68-69 - 1500 - 8mm oil pump studs B6 - 70 - 1600 - Dual Relief - single port AE - 71-72 - 1600 - Dual Relief - Dual Port AH - 73-74 - 1600 - 8mm Head studs w/case savers AJ - 75 - 1600 - Fuel injected, no fuel pump mount. Type 2 Code Year Engine Remarks Numerals 61-63 - 1200 - See type 1 40 HP O - 64 - 1500 - No Cam bearings H - 65 - 1500 HO - 66-67 - 1500 - No Cross member holes B5 - 68-69 - 1600 - 8mm oil pump studs, single port B5 - 70 - 1600 - Dual Relief AE - 71 - 1600 - W/cross member holes Late Bus CB - 72-73 - 1700 - Dual carb, manual trans CD - 73 - 1700 - Dual carb, auto trans AW - 73-74 - 1800 - Dual carb, manual or auto AW - 75 - 1800 - Fuel injected ED - 75 - 2000 GD - 76-79 - 2000 - 79 had Vanagon heads GE - 79 - 2000 - Cal only, Vanagon heads Type 3 Code Year Engine Remarks O - 63-65 - 1500 - No Cam Bearings TO - 66-67 - 1500 - 6mm oil pump studs UO - 68-69 - 1600 - Fuel injected ‘69 w/xmember holes UO - 70 - 1600 - xmember holes, dual relief U5 - 71-73 - 1600 - like UO w/xmember holes 7.3:1 compresion X - 72 - 1600 - 7.3:1 compresion After Market Cases Code Year Engine Remarks F1 - 13/1600 F2 - 13/1600 DO - 40-HP part when last digit is "X" D1 - Some times a 40-HP part AB - 66-79 - 1600 - Built since ‘73 in Mexico, Brazil and Germany AK - 67-74 - 15/1600 AM - 1600 AS - sometimes listed as a Super Beetle original case ‘73 and on Type 4 Code Year Engine Remarks W - 71 - 1700 EA - 72-74 - 1700 EB - 73 - 1700 - Calif only EC - 74 - 1700 |
