| power ?? http://woodsbuggy.com/phpBB3/viewtopic.php?f=3&t=12457 |
| Author: | buggyman20 [ Mon Oct 17, 2011 1:03 am ] |
| Post subject: | power ?? |
what kind of power will a motor with 87 jugs and pistons with vw 75 dual port heads and a solex pict 3 one barrel carb with 009 distributor and a power pully have ?? |
| Author: | passat2800 [ Mon Oct 17, 2011 10:49 am ] |
| Post subject: | Re: power ?? |
Put the stock size pulley back on. It ain't worth the cooling loss.I'd say with a header and stock comp. ratio, flat top pistons, 75 on a good day.That distributor is just for a little quicker response. |
| Author: | RaceBugg1098 [ Mon Oct 17, 2011 12:07 pm ] |
75 hp is pushing it. I would think more like 65 on a good day.Keep in mind a good running middle of the road 1915 with dual 44's MIGHT make 100 hp. |
| Author: | buggyman20 [ Mon Oct 17, 2011 10:13 pm ] |
i had a electronic distributor on it and just didnt run right with it, so i put the 009 on it and runs alot better |
| Author: | kybuggy1 [ Mon Oct 17, 2011 11:37 pm ] |
buggyman20 wrote: i had a electronic distributor on it and just didnt run right with it, so i put the 009 on it and runs alot better Drop a pertronix ignitor in that 009 and REAL Bosch cap and rotor and you'll have excellent performance and better reliability than any aftermarket distributor. |
