Motor build
http://woodsbuggy.com/phpBB3/viewtopic.php?f=3&t=12260
Author:  jackson.ryan29 [ Thu Sep 01, 2011 2:15 pm ]
Post subject:  Motor build
1641cc vz15 webber progressive 044 heads counter weight crank? Think it will have enough to push my rail? Decently? :?:
Author:  ridenrace6 [ Thu Sep 01, 2011 3:20 pm ]
Post subject:  Re: Motor build
i would use a 110 , i dont think the vz15 will have enough bottom end in a 1641, i had a 1641 with single webber idf and a lightened flywheel, 110, and 044's and it ran great (everbody thought it was a bigger motor but it wasnt) but my 1915 with the same setup and a v15 only has about the same bottom end or maybe even not quite as much, my 2 cents
Author:  hyde [ Thu Sep 01, 2011 4:08 pm ]
Vz 15 is what a lot of guys run in 1600 race buggys & it is fullthrottle all the time not much low rpm's. For a woodsbuggy build as big eng. as you can . Forged Piston for a 1641 is the same $$$$ as 1915 or 2500 . If 1641 is it then I would run a W 100 & mild port work on the heads with 1.25 rockers with 9.5 compression for 93 pump gas or 12 to 1 for race gas . My 2 cents call Drews or other sponsors for there 2 cents
Author:  Buckmaster [ Thu Sep 01, 2011 6:24 pm ]
You like to climb big hills or trail ride is the question and what tranny do you have?
Author:  jackson.ryan29 [ Sat Sep 03, 2011 8:27 am ]
Love the hill but like to put throw the trails and drink beers also! I don't want to put a cam in there that is going to overload all the time and I can't build a big motor till tax time!
Author:  ridenrace6 [ Sat Sep 03, 2011 2:56 pm ]
i dont think you will go wrong with a engle w110, it will work good all around in pretty much any size engine
i loved it in my 1641 with 1.25 rockers and i love it in my 2498 with 1.4 rockers
Author:  jesse [ Sat Sep 03, 2011 3:38 pm ]
go 110
