It is currently Mon May 04, 2026 4:33 am
 Post subject: Maine bearing
PostPosted: Tue Sep 18, 2007 9:11 pm
Help can anyone tell me why this bearing spun I know it was lack of oil . Motor was running no noise at all the only way we found it installing new dist turn motor by hand and it lock up . Could motor block be bad or crank bad it isImage a 1915 vz 15 cam dual weber 40s
PostPosted: Wed Sep 19, 2007 6:22 am
Lack of oil will do it every time. Usually a bad case will cause this. Bad fitmet of bearing in the case.
