It is currently Mon May 04, 2026 10:27 pm
 Post subject: problem and question
PostPosted: Mon Aug 22, 2011 6:05 pm
motor started making noise so we looked into it and found out the push rod was messed up any clue what could cause this
befor:
after:
 Post subject: Re: problem and question
PostPosted: Mon Aug 22, 2011 6:41 pm
yeah two thing come to mind to much vavle seat pressure or poor oiling and maybe worn rocker arms
PostPosted: Mon Aug 22, 2011 7:02 pm
well the motor was just built only 3 rides on it if that helps any
PostPosted: Mon Aug 22, 2011 7:04 pm
and it had plenty of oil in the valve cover when we took it off and had plenty in the push rod itself and the tube
PostPosted: Mon Aug 22, 2011 7:27 pm
What brand push rods are they?
PostPosted: Mon Aug 22, 2011 7:30 pm
i have no clue its my friends motor they may have been to tight so we gonna put another one in and set them right and see what happens
PostPosted: Mon Aug 22, 2011 8:30 pm
How big is the hole in the rocker or lifter! That looks like precise lathe work.
PostPosted: Mon Aug 22, 2011 8:39 pm
I had some EMPI lifters go bad after only a few hours of riding. Did not shape the rod the same way but it wore down the rod so far that the rod fell out and binded.
PostPosted: Tue Aug 23, 2011 12:03 am
which end did that, the lifter end or the rocker arm end and what brand rockers, lifters, and pushrods ?
also what type rocker arms, stock style (aduster on the valve end), or aftermarket (adjuster on the pushrod end) ?
PostPosted: Tue Aug 23, 2011 12:09 am
Looks like those pushrods are made out of peanut butter! You better make sure the cam isn't going or already gone flat also.
PostPosted: Tue Aug 23, 2011 1:42 am
i have no clue about whats in his motor i know its not stock parts and its a 2065 i think i will have to get more info from him if the problem continues
PostPosted: Tue Aug 23, 2011 3:14 pm
I heard about a certain company having all kinds of problems with the push rods doing that. They had a bad batch of ends from the heat treater or something. it was either bugpack or empi or even CB i think. The ends all come from the same place i bet.
