48-ida empi prob please remove this post
http://woodsbuggy.com/phpBB3/viewtopic.php?f=3&t=12088
Author:  darrell [ Thu Jul 28, 2011 8:18 am ]
Post subject:  48-ida empi prob please remove this post
i have a 2443 with 2 empi 48 ida runs great but when i rev it up its got a gas smoke it will burn your eyes out has a 1.50 main jet 55 idle .i was thinking about going to 1.35 mains any one think that would help .i am hoping i dont have bad valve guide super flow heads.
Author:  jason108 [ Thu Jul 28, 2011 12:29 pm ]
Post subject:  Re: 48-ida empi prob
try to adjust your idle (bigger) it plays a big part in the final output. just my opinion but i would try there first.
Author:  darrell [ Thu Jul 28, 2011 1:12 pm ]
A bigger idle jet or just a faster rpm idle
Author:  hyde [ Thu Jul 28, 2011 5:45 pm ]
I would start with Checking spark plugs to see what they look like . & timing about 32de then floats level then fuel pressure 3psi then try small main jets or biger air jet . Ida like to have a 3rd progression port to make the fuel curve more flat . Call empi or cb for a update kit .
Author:  darrell [ Thu Jul 28, 2011 7:04 pm ]
plugs look a little rich .timing is at 30 de now and floats is good i have messed with webers a ton my first set of ida im thinking intake guide im just hoping not :?: :roll: like i said engin sounds great does not mis or stumble just gas smoke it gets worse the longer it runs. people have told me that the super flow heads had a prob. with guides i just dont no if the guides would couse this prob.man that would suck :(
Author:  chris38375 [ Thu Jul 28, 2011 8:12 pm ]
go down on ur idles down go down on ur mains if it runs good over 2500 rpm,ur motor runs on idle jets about 80% of the time so try 45s on ur idles then go to 50s if its to lean
Author:  darrell [ Thu Jul 28, 2011 10:10 pm ]
this is my next move thanks .i will let you know how it turns out .
Author:  ridenrace6 [ Fri Jul 29, 2011 2:56 am ]
im thinking 135 or maybe 140 on the main jet and either 55 or 60 idle and about 175 or 180 air jet should get it fairly close
just my 2 cents
Author:  darrell [ Fri Jul 29, 2011 9:00 am ]
just my 2 cents
all the info i can get i will take it .thanks im just getting a little worried big money in this motor .i at least wont to have a little fun in the woods before i tear it back apart . maybe i should have stuck with 2332 with webers :?:
Author:  DVS1 [ Fri Jul 29, 2011 12:42 pm ]
Here's some calculations:
Venturi : 2 to 4mm smaller than intake valve
Idle : Venturi size x 1.6
Idle Mix: 1 to 1.5 turns out
main jet: 4.1 to 4.3 x venturi size
Air jet: 200 if mains are approx. 145 / 180 if mains are approx 135
These helped me dial in my 44's and I run SuperFlo's also
Author:  hyde [ Fri Jul 29, 2011 5:47 pm ]
Super flow have no more guide prob. then other vw head . Start play with carbs & look in to the 3rd progression port . Do a leakdown to check piston rings.
Author:  darrell [ Sat Aug 13, 2011 3:00 pm ]
new rings fixed it. i thought it was gas smoke just want to say thanks to everyone they are good people left in the world THANKS.
