| need some info on timing and fuel pressure http://woodsbuggy.com/phpBB3/viewtopic.php?f=3&t=11936 |
| Author: | diamonddav [ Tue Jun 28, 2011 8:22 pm ] |
| Post subject: | need some info on timing and fuel pressure |
i got a 1641 w/ engle 100 cam, just bought a weber 40 idf carb for it, installing tonite, but last time out i was having problems and stuck like chuck and drunk so i started messin with the distributor tryin to get it to crank better! think i was hydro locked cuz of the junk solex carb but anyhow, puttin new carb on it with a fuel pressure regulator. what should i set the regulator at? im thinkin 2 psi but would like some input. also at what degree should my timing be set at when i get all together and running, thanks in advance for any info and help! tryin to get this thing runnin for the hillclimb at harlan!!!!!!!!! see you all there |
| Author: | bluebuggy [ Tue Jun 28, 2011 8:40 pm ] |
| Post subject: | Re: need some info on timing and fuel pressure |
4psi Is what i think most run or i have in the past and 7.5 BTDC |
| Author: | Aaron Creech [ Wed Jun 29, 2011 12:27 am ] |
Are you running a stock pump or electric? If stock you don't need a regulator.That carb only needs about 2-3 psi.Set the timing at 30 degrees at 3000 rpm.Run 93 octane gas. |
| Author: | Odyknuck [ Wed Jun 29, 2011 8:16 am ] |
Aaron Creech wrote: Are you running a stock pump or electric? If stock you don't need a regulator.That carb only needs about 2-3 psi.Set the timing at 30 degrees at 3000 rpm.Run 93 octane gas. Curious why you would run 93 Octane in a 1641 motor. Is the compression above 8.5:1? Regular gas actually burns hotter and will produce more power than a higher octane that is formulated for higher compression motors. |
| Author: | chris38375 [ Wed Jun 29, 2011 9:31 am ] |
Odyknuck wrote: Aaron Creech wrote: Are you running a stock pump or electric? If stock you don't need a regulator.That carb only needs about 2-3 psi.Set the timing at 30 degrees at 3000 rpm.Run 93 octane gas. Curious why you would run 93 Octane in a 1641 motor. Is the compression above 8.5:1? Regular gas actually burns hotter and will produce more power than a higher octane that is formulated for higher compression motors. inside the fuel lid on a stock beetle says 92 octane min. |
| Author: | Odyknuck [ Wed Jun 29, 2011 10:29 am ] |
Ah! I did not know that. I stand corrected. |
| Author: | diamonddav [ Wed Jun 29, 2011 11:49 am ] |
arron its an electric pump, i have an aj block, originally fuel injected. ray and erics my buds, i'll be comin to see you soon!so would 2 setting be fine? |
| Author: | bige70chevy [ Wed Jun 29, 2011 6:40 pm ] |
diamonddav wrote: arron its an electric pump, i have an aj block, originally fuel injected. ray and erics my buds, i'll be comin to see you soon!so would 2 setting be fine? put it right before 3 and you should be good to go |
