It is currently Mon May 04, 2026 8:13 pm
 Post subject: new 1835 build
PostPosted: Wed Apr 13, 2011 8:20 pm
just built a new 1835. stock dual port heads,110 cam ,stock crank , empi 44 idf ,petronix electric distributor.
seems like 1 and 3 cylinder does not hit as hard as 4 and 2.i have rechecked everything.its got good power ,just not what i think it should.at idle 1 and 3 seems like they are barely hitting. whats wrong.is the setup wrong?
 Post subject: Re: new 1835 build
PostPosted: Wed Apr 13, 2011 9:24 pm
check valves and timing? maybe jetting is off a little? check , recheck, then check check check again lol
"IT IS WHAT IT IS"
PostPosted: Wed Apr 13, 2011 9:27 pm
Is it a dual 44 set up or single. If its dual check your float levels and check for clogged jets and passage ways. Ive seen a bunch of empi carbs bad out of the box but you must check and make sure its not another problem.
PostPosted: Thu Apr 14, 2011 6:30 am
single 44,i changed idle jets.i changed plugs,wires. i keep thinking it might be the new pertronix.i took it completly back apart.could not find any thing wrong.
PostPosted: Thu Apr 14, 2011 8:15 am
the ignition is a good possibility, Ive had that happen to me before to. Also check the cam. With the problem being between #1 and #3 you may have a worn cam lobe. Take the valve covers of and make sure the valves are all opening the same.
PostPosted: Thu Apr 14, 2011 12:06 pm
The petronix should either work or not work. Not really anything in between. a cam can wear out in the first 30 seconds of runing if not lubed enough. possibly intake leak?
PostPosted: Sun Apr 17, 2011 8:59 pm
how rough should this thing idle.should it sound close to stock.i am in the dark on these engines,this is my first round with vw power.i am thinking what i am hearing might just be the nature of it.what do you guys think?
PostPosted: Mon Apr 18, 2011 12:52 pm
It depends on the cam. If its stock yes. Although I have seen a bunch of single idf style set ups on stock motors cut up like they have a big camshaft. Pull the spark plugs out and see what color they are. If they are black you need to go down on idle jet size. You want them to be brown.
PostPosted: Mon Apr 18, 2011 8:56 pm
Ck the comp. on all the cyl's with a comp. gauge and see if they are all equal if they are look @ the ignition or fuel if they are different look at the internals .
PostPosted: Sun Apr 24, 2011 9:12 pm
i am putting i back together. 1835 stock crank, 110 cam , heads are off fuel injected engine,pertronix setup, single 44 hpmx carb. i found nothing wrong. i have heard some bad stuff about these carbs.i will let everyone know how it turns out.
PostPosted: Sun May 22, 2011 10:19 pm
1835 with 110 cam will idle rough and smooths out at about 1000 rpm. as far as 1 and 3 goes, that is normal because of the firing order and the single carb intake. The only way to cure that is dual carbs. It does not seem to effect power at all. Increase your idle and don't worry about it. 041 heads would be a good choice.
