OIL FOAMING ON DRYSUMP MOTOR
http://woodsbuggy.com/phpBB3/viewtopic.php?f=3&t=11609
Author:  pops [ Thu Apr 21, 2011 6:25 pm ]
Post subject:  OIL FOAMING ON DRYSUMP MOTOR
just started new motor primed all lines till got pressure looked in tank and the oil looks white from all the foam it is synthetis castrol 10w30 never hade this prob before any in put all lines r ran correct THANKS TONY POPS SON IT WILL NOT LET ME LOG IN UNDER WILD PINTO
Author:  gasman [ Thu Apr 21, 2011 9:21 pm ]
Post subject:  Re: OIL FOAMING ON DRYSUMP MOTOR
Is this the only brand of oil that's ever been in it?some brands if mixed will foam a little.Chad :mrgreen:
Author:  pops [ Fri Apr 22, 2011 12:03 am ]
Rotella 15-40 in the past but all lines and tank and cooler and filter were replaced or cleaned because motor blew up after sheering dowl pins I'll post video of inside of tank tomorrow. I am going to Change to a thicker oil tomarrow to see if this helps. The oil pressure idling is 45psi crack the throtle it jumps up to about 90 psi at 7500rpm but it is foaming while idling shut the engine down and ten min later small bubbles r still comeing to surface .
Author:  ridenrace6 [ Fri Apr 22, 2011 12:06 am ]
sounds like a line may be letting it suck air somewhere around a fitting or maybe even the pump itself, just a thought
is it the bugpack or cb pump?
Author:  Odyknuck [ Fri Apr 22, 2011 4:26 pm ]
Are those pressures with engine Cold or Hot. If when Hot sounds like your actually flowing to much oil.
Author:  pops [ Sat Apr 23, 2011 8:39 pm ]
Sent a sample of oil to castrol dumped that shit out replaced with Rotella t know there isn't any foam at all castrol explained about there oil being a detergent oil and it has additives to clean the inside of motor I personly think it's BS but ran the shit out of it today with no problem thanks for input
Author:  kevin f [ Sat Apr 23, 2011 9:52 pm ]
Boy did you run the shit out of it. I ran the shit out of mine to. Stoney lonesome has stepped up in the world. Every time we go now that its under new managment I like it more. Your buggy is bad ass tony, it blew my mind at how easy it made everything look. :)
