It is currently Mon May 04, 2026 1:30 am
 Post subject: valve adjustment
PostPosted: Sat Feb 12, 2011 9:07 pm
doing a tune up on buggy...need to know correct way to adjust valves...have heard a few different things...1641 w stock heads
 Post subject: Re: valve adjustment
PostPosted: Sat Feb 12, 2011 10:27 pm
Google VW aircooled valve adjustment.B4 you start check the condition of your push rods. See if the heads aren't beat down inside the rods and look for a 3/4" long clean silver spot where they may be flexing and rubbing the block.Noticeable rev and power loss. :?
PostPosted: Sat Feb 12, 2011 11:54 pm
still plenty of power and rpms but gettin a little noisy on passenger side
PostPosted: Sun Feb 13, 2011 10:46 am
Compression
Stroke Its #1 at TDC with your rotor button pointing at #1 plug wire on distributor,adjust to .006",then 180 degrees ccw or 1/2 turn ccw, then do #2 then another 180 degrees or 1/2turn ccw to adjust #3, then another 180 degrees to adjust #4.1-4-3-2 firing order .006" tight all around.try this.I copied it from another post,then had to redo it after reading it lol.but try this.Chad :mrgreen:
