It is currently Mon May 04, 2026 10:31 pm
 Post subject: single port to dual port
PostPosted: Mon Nov 22, 2010 2:55 am
i have a buddy thats tryin to put a buggy together he has a single port motor, i gave him a set of dual port heads can he run them on his single port engine?
Brandon
PostPosted: Mon Nov 22, 2010 9:15 pm
No problem. He will just need dual port end castings and manifold.
PostPosted: Mon Nov 22, 2010 10:32 pm
WB Competitor
my buddy has a single port he wants to get rid of. i called and left you a message last night. it was running when he took it out to go to a bigger engine. check your messages and give me a call. its for sale or trade maybe for those v tread tires you have. pm me or call after 4:30 tomorrow.
PostPosted: Mon Nov 22, 2010 10:52 pm
You gotta change a few cylinder head studs out.I think the 4 on the top.
PostPosted: Tue Nov 23, 2010 1:51 pm
Yup.
The pair on the top in the center has to be changed or shortened.
SP carb is smaller too.
Need the 34 PICT that comes on the DP or an adapter to use the 30 that comes on the SP.
Head tins are different.
This is provided his SP engine is a 1500/1600.
1200 and 1300 engines look very similar.
PostPosted: Wed Nov 24, 2010 12:58 am
not been out to get service, ill give you a yell
Brandon
