It is currently Mon May 04, 2026 4:34 am
 Post subject: New to building a motor.
PostPosted: Thu Oct 07, 2010 9:45 pm
Ok so this will be my first vw motor rebuild i have never done this before i dont think it is going to be a problem i have rebuilt water cooled motors before. I just want to know are there any things that you need to do special for these motors different.
my motor is a 2167 78mm crank 94mm pistons 5.5 rods VZ-15 cam heads im not sure on yet.
PostPosted: Fri Oct 08, 2010 11:34 am
The typical VW manual will cover pretty much all you need to know. They are not a diffucult motor to rebuild for someone with good mechanical abilitys. Beacuse you are rebuilding and not starting from scratch most of the clearencing has already been done. I dought you will have any cam clearence issues with that small of a crank however double check. Getting the correct Rocker arm ratio is real Important in the VW motor. Check your deck height etc when replacing the P & Cs. Watch when you install your distributer drive gear. The shims like to drop in the motor. make sure you have clearence between the Cam gear bolt heads and the back of the Oil pump. Check your head stud Inserts to make sure they are not pulling out.
