 Post subject: type 4 motor
PostPosted: Wed Aug 29, 2007 6:31 pm
i'm thinking of building/buying a type 4 motor to run at wellsville.
just looking for advice (pros and cons)
- Sigmund Freud
- Antonio Meloni
 Post subject: type 4 motors
PostPosted: Wed Aug 29, 2007 9:32 pm
Hate to hijack your title, but was also wondering from people what a stock type 4 2.0 is comparable to in a type 1? Also wondering if dual 45 dell's will work on a stock 2.0 type 4 motor? Any info would be greatly appreciated!!!
Wife says NO MORE Internet $$ pits!!!
PostPosted: Thu Aug 30, 2007 9:28 am
The stock T4 2.0 would be a better motor that a comparable T1 in the same size for a woods buggy. They have lots of torqe for hill climbing and low speed riding. Your able to lug them when ypur in between gear requirements. Not great for high speed due to they fall flat at high RPM however for woods riding you dont need much more than 4500 RPM anyways. The disadvantage of the T4 is you would really need to convert it to aan upright cooling system to keep the weight down and to not have the inlet of the cooling fan on the back of the engine down low.
PostPosted: Thu Aug 30, 2007 9:30 am
On the 44s, they would work find. You will have to buy a set of T4 carb intakes for them. Also you will need a T4 exhaust. There is only a few sources for them and they are pricy or you can make one.
 Post subject: Type 4 motor
PostPosted: Thu Aug 30, 2007 5:30 pm
Thanks for the tips. I have an existing built type 4 motor but it has bad heads (48x38mm) and needs new pistons,rings,and 96mm jugs. Don't really want to split the case but it is to have FAT performance crank, and cam and heads. So I have the upright fan,45 Dells, and exhaust already. Just don't want to invest the money right now to look the whole motor over. I am going to buy a stock 2.0 type 4 rebuild long block for now until I can rummage enuff money up to re-do the built motor. Does anybody know where I can get the best deal on a rebuilt 2.0 Type 4 ???
PostPosted: Tue Sep 04, 2007 2:02 pm
You should call Curts dad, Bernard. He built me a 2950cc type 4 that I ran in the woods. This thing was a ground pounder, forgot crank size but it had 105mm pistons, 40x 50mm valves,ported heads, upright fans, & trimil stinger that was 2" but I cut it off and made it 3". I think he still has enough parts to build another one, of course you will have to go thru curt to get his number.
PostPosted: Tue Sep 04, 2007 2:44 pm
What........................................NO Drilled Valves? :twisted:
PostPosted: Wed Sep 05, 2007 9:20 am
PLEASEEEEEEEEESSSSS DONT START!
- Sigmund Freud
- Antonio Meloni
PostPosted: Wed Sep 19, 2007 7:53 pm
Put a Subaru 2.5 turbo in it and be done! Right Mike
PostPosted: Thu Sep 20, 2007 10:33 am
[quote='Stevo']Put a Subaru 2.5 turbo in it and be done! Right Mike[/quote]
thought about it.............got no room for the radiator because of the pickup style frame.
- Sigmund Freud
- Antonio Meloni
PostPosted: Thu Sep 20, 2007 1:17 pm
If you go to shoptalkforums.com and check out the Type 4rum, you will find all the info you need about T4 engines....
PostPosted: Thu Sep 20, 2007 3:11 pm
[quote='Daniel G']If you go to shoptalkforums.com and check out the Type 4rum, you will find all the info you need about T4 engines....[/quote]
thanks, there is alot of good info there but it seems like most of t4 guys are into street/strip not to many "woodsbuggys" still an excellent place for info
- Sigmund Freud
- Antonio Meloni
PostPosted: Thu Sep 20, 2007 9:08 pm
As far as rpms with a type IV, it depends on how you have it setup. My 1.7 I had in my 914 would come alive around 3K and fall on its face right around 7K. I'm running a 2.5 subi in my baja cause it big and heavy and I already had the engine. I ran a 2.0 vanagon type IV in my last rail. I would run another type IV in a rail in a heartbeat. I liked it much better than my type 1. I would prefer to fuel inject the next one. I ended up with dual 44 idfs on the last one. I tried a centermount weber progressive to start with. Don't waste your time on that one.
John
 Post subject: Re: type 4 motor
PostPosted: Thu Sep 20, 2007 9:09 pm
[quote='plumberbill']i'm thinking of building/buying a type 4 motor to run at wellsville.
just looking for advice (pros and cons)[/quote]
Hi,
New to the site...full of great information.
I'm currently putting a 1.7 Typ.4 in my ancient warrior chassis.
The only necessary modification I needed to do was to remove the needle bearing from the end of the T4 crank and bore the flywheel and press fit a new needle bearing in the flywheel.Use a new Typ.1 bearing,press bearing in until t
PostPosted: Fri Sep 21, 2007 9:06 am
thanks guys for all the info
- Sigmund Freud
- Antonio Meloni
PostPosted: Thu Oct 11, 2007 7:08 am
Hi new to this forum but have been useing T4's for a few years .bolth in my 912 and a woods buggy with a stock 2.0lt with a center mount webber and two stingers and i can tell you this, it would keep up with just about any thing out here . had lots of grunt and i think it would out do the 1914 i had in my last rail. this is a pic of the rail . it has since been sold and the next rail i am building is getting my 2056 that i built for my porsche.
PostPosted: Thu Oct 11, 2007 9:32 am
[quote='vw505']Hi new to this forum but have been useing T4's for a few years .bolth in my 912 and a woods buggy with a stock 2.0lt with a center mount webber and two stingers and i can tell you this, it would keep up with just about any thing out here . had lots of grunt and i think it would out do the 1914 i had in my last rail. this is a pic of the rail . it has since been sold and the next rail i am building is getting my 2056 that i built for my porsche.
[/quote]
first off wel
- Sigmund Freud
- Antonio Meloni
PostPosted: Thu Oct 11, 2007 9:49 am
ya tell me about it . i have a DTM and ham heads. i have two motors to use one is a 2180 roller crank motor and my T4 my stock t4 was just so smooth running off road i think i am going to stick with them and save the other for a porsche 550 kit car.
are you planing on rebuilding the T4 if you do get your cam from jake and let him know what you have in it and what you are doing with the car my cam is a bit big for off road so i may change it out . this is the car i am putting it in.
PostPosted: Thu Oct 11, 2007 3:23 pm
I know a guy that runs t4 motors in woods buggies and loves them. He currently runs a 2666cc and is working on a turbo charged 28??cc motor. He is an excellent source for q&a. His email is bevans37095@yahoo.com.
Where did you say the weenie trail is?
PostPosted: Thu Oct 11, 2007 3:28 pm
intresting buggy.......looks like my first buggy
- Sigmund Freud
- Antonio Meloni
PostPosted: Thu Oct 11, 2007 3:30 pm
[quote='buggymethis']I know a guy that runs t4 motors in woods buggies and loves them. He currently runs a 2666cc and is working on a turbo charged 28??cc motor. He is an excellent source for q&a. His email is bevans37095@yahoo.com.[/quote]
thanks bm does he post here on wb?
- Sigmund Freud
- Antonio Meloni
PostPosted: Thu Oct 11, 2007 8:55 pm
do you remember who made that buggy ? and do you have any more pics of it ? like the front beam? i have 2x3 on the rear and was wanting to do a little somthing with the front .
PostPosted: Fri Oct 12, 2007 12:06 am
i bought that buggy from blbronc (blake) a couple of years ago. i sold it to a friend of mine when i built my current buggy around 2 years ago. blake could tell you who made the frame i dont remember. the beam i had made by drews offroad in southern ohio it is 8" wider with custom shock towers. the orignal beam that came with it when i bought it got ripped apart in a wreck. i had pics but lost them when my computer crashed.
this buggy had a smooth ride, there are these rr tracks where we ride and next to them is a dirt road that has small wups, one after the other. most buggys just use 1st or 2nd gear. i used to hit 3rd and fly through the wups
like they were nothing. i think it had something to do with that long front end either way that buggy was sweet.
the rear trailing arms were at least 3x3 if not longer, once again blake might remember. he might even have some pics.
b.t.w. its currently fs on ebay.
- Sigmund Freud
- Antonio Meloni
PostPosted: Fri Oct 12, 2007 2:21 pm
You have a link to it ?
PostPosted: Fri Oct 12, 2007 11:22 pm
http://cgi.ebay.com/ebaymotors/Sand-Car ... enameZWDVW
- Sigmund Freud
- Antonio Meloni
