It is currently Tue May 05, 2026 2:50 am
 Post subject: wont start
PostPosted: Tue Sep 21, 2010 10:29 pm
I have a stock 1600 I just rebuilt new bearings seals pistins juggs the whole 9 yards, put it in and it won't fore, its getting spark and its getting fuel, everything is normal, it will turn over slow but it turns over but will fire any ideas?
if you cant duck it fudge it
 Post subject: Re: wont start
PostPosted: Tue Sep 21, 2010 10:49 pm
Is it turning fast enough to start? Did you set the static timing? Any chance the cam is not timed to the crank?
PostPosted: Tue Sep 21, 2010 10:57 pm
yep sounds like timing i would look eveything over again :) you will get it
PostPosted: Tue Sep 21, 2010 10:59 pm
put the one dot between the two dots in the cam and crank
PostPosted: Tue Sep 21, 2010 11:28 pm
i would look at the Distributors i have even taking the cap off and looking at the rotor and looking at the wires and then even looking at the rockers to make sure the Valve are closed, but if its turning slow sounds like its just 30 or more out if you have points static timing is the way to set the timing
http://www.vw-resource.com/vw-resource. ... tml#static
PostPosted: Wed Sep 22, 2010 12:43 am
Just dosent wanna turn over its so slow i think thats why it wont start changed starters and still does it and what is static timing?
PostPosted: Wed Sep 22, 2010 1:28 am
How does it turn over by hand?
While the starter could be bad make sure the battery is good and the cable connections at both ends are clean. A missing/dirty transaxle to pan ground strap can also make it drag. Sometimes the battery cables can get resistance in them.
Its to hard for me to descibe static timing so I cheated and gave you a link.
http://www.vw-resource.com/tune-up.html#static
PostPosted: Fri Sep 24, 2010 12:55 pm
Have you made any progress.
Someone found a video of setting static timing:
http://www.youtube.com/watch?v=f9jh7POU ... re=related
PostPosted: Sat Sep 25, 2010 6:23 pm
yes sorry have been busy got it figured out the timing was 180 out, like an idiot i didnt set the distributer gea right and pulled it set it and it started right out, thanks for all the help every one, puttin this motor in the baja, and starting on my next motor next week wanna go pretty big for my buggy and i picked up a three rib so its gonna b a long week
PostPosted: Sat Sep 25, 2010 6:54 pm
Glad it was turned out to be a simple fix.
