| Running Fat/fouled plugs http://woodsbuggy.com/phpBB3/viewtopic.php?f=3&t=10222 |
| Author: | Bones_99 [ Tue Sep 07, 2010 1:53 pm ] |
| Post subject: | Running Fat/fouled plugs |
Well I finally was able to shake down my buggy since i got it to see what i need to do to it. Well I noticed that It was not running well. You had to rev the crap out of it to get it to move. Thought that it was odd but never had a VW so i really didnt know. I noticed that I was running really fat. You could smell the unburnt fuel coming out of the exhaust. So i decided to pull the plugs and see what they tell me. Sure enough it is running really fat and it had fouled the plugs. I grabbed a new set of plugs and gapped them to .35 and threw them in. WOW it ran 1000x better than it did before. The problem that I am having is that its still running really fat. The carb thats on it is an EMPI Progressive. Thats all I really know about it. Is their any markings on it that might help me identify it?? I will try and snap a picture of it tonight. The motor is a 1641 Dual port with a T-100?(the kid told me t-100 but i can only find info on w-100) cam in it. It was recently rebuild and has not been run a whole lot. Thats all I really know about the motor. Any help would be great. |
| Author: | Dave Winterburn [ Tue Sep 07, 2010 3:10 pm ] |
| Post subject: | Re: Running Fat/fouled plugs |
Different carbs but sounds like problem I had. Floats not closing needle valve. Do you smell fuel in the oil? I hear that EMPI carbs are hard to set up. |
| Author: | Bones_99 [ Tue Sep 07, 2010 3:22 pm ] |
Have not checked but I will do that tonight. Thats what I have been reading as well. |
| Author: | perrib [ Wed Sep 08, 2010 12:20 am ] |
Here are some links to progressive help. If it is not the needle valve or float adjustment try a smaller idle jet. What makes them a bear to work on is you have to remove the carb to work on it. I'm not sure what the float setting is but starting at level should get you close.Some where on the Weber web site is the reccomended drop for off roading. Here is a good picture of setting the float level. http://board.marlincrawler.com/index.php?topic=62976.0 http://www.redlineweber.com/html/Tech/3 ... akdown.htm http://www.redlineweber.com/html/Tech/3 ... akdown.htm http://store.cip1.com/Merchant2/graphic ... 36DFEV.pdf From John at aircooled.net MAKING PROGRESSIVES WORK If you have an EMPI progressive, you got hosed. Get a real Weber DFAV/DFEV. Don't run a 009 or other centrifugal only distributor. They suck! Run our SVDA, it will make your tuning job MUCH easier. Good progressive carbs HAVE the proper port for the SVDA, if they do not you got a chinese copy or an old (ie: obsolete) progressive, and you will HAVE no other choice but to run a 009/010, but you will NOT have optimal tuning results like you would if you had a SVDA. Centermount Progressives NEED intake heat, and lots of it. This is why a progressive on a T4 WILL NOT WORK. It's so bad and unfixable, we do not even sell the kits that are available for the T4. It will not work, do not ask, because the answer is "get dual carbs". Nuff' Said. On a T1, the stock muffler is setup perfect, just make sure they are clear. But if you have an aftermarket header with the flanges on #2 and #4 primaries, you must relocate one of them to the collector (like the stock muffler!) to get good preheat. Don't be a lazy ass and think you are special and that these rules don't apply to you. Just relocate one to the collector, with some small steel tubing, and weld/braze it in place. Or have the guy at the muffler shop do it, it's an easy job for him. If you don't do this relocation modification, don't bitch about the flat spot and poor MPG, along with needing "wack" jetting (like a richer primary than what I use). The intake preheat keeps the fuel that is metered at the carburetor (by the idle and main jets) VAPORIZED (Google "Latent Heat of Vaporization"). Your intake heat is of a fixed amount. The richer it is, the colder the intake is going to be. Don't be any richer than you have to! If the intake is cold, you have to jet rich to make sure that the air/fuel reaching the cylinder is rich enough, because a lot of the metered fuel condensed on the way to the cylinder because it's cold (not vaporized), and a long ways from the carb to the cylinder. So you have fun stuff like when you rev it up, all that condensed liquid fuel puddled in the intake makes it's way into the cylinders and now you are way rich. Intake heat IS A GOOD THING for centermounts! Even if it's 120F in the desert, the intake heat is a good thing! The more heat you route to the intake, the leaner you will be able to jet the carb, and keep the A/F the same. If you have a wideband, you'll see that as you add heat to the intake, it will run richer, since you are keeping fuel vaporized and it will combust properly! I've even recommended to some guys that didn't want to hack their exhaust to have simply routed their hot engine oil thru the preheat tubes, which has the double benefit of heating the intake and cooling the oil AT THE SAME TIME. If you have a porous intake (ie: CHEAP) you are SOL on this one, it will leak. http://www.aircooled.net/new-bin/viewpr ... d2=FSK0028 is a good intake. Also, good intakes route the heat to the carb base, NOT just along the bottom tube. If you see a bottom tube only preheat model, walk away from it, it sucks. PERIOD. A good intake is not that much, and solves the progression linkage issue also (the carb doesn't line up with the throttle cable. Cheap kits have a ghetto connection from cable to carb, that doesn't even open the carb all the way up at WOT. The good intake will fix the linkage issue, with a McGyver like arrangement on the manifold. It works very well. I will also say that hot air intake also helps your cause. Figure a way to get hot air from under the engine, to the air intake on the carb. All Webers also need 3-3.5psi fuel pressure, and the floats set to spec. They are NOT SET when new, so learn to work on the carburetor! These 4 things (fuel pressure, float level, intake heat, hot air intake) are NOT done by 99% of progressive owners, and the cause of the bad rap. The next issue is jetting. I have not once, in 30 years of working on these things, seen a progressive properly jetted, not even CLOSE, if I haven't worked on it first. I have also never seen a store that properly jet a progressive. Their "charts and guidelines" are horrible. HORRIBLE. It's like they want you to blow up your engine and wear out your rings/pistons from fuel washdown, in 5k miles. So, on we go. Here are my guidelines for progressive jetting. Primary idle, 45-50 at sea level, 40-45 @ 5k'. Secondary idle 10-15 larger than primary idle. Weber supplies them with the primary idle larger than the secondary, WHICH IS STUPID. It runs too rich on the primary, then leans out when the secondary opens. The more intake preheat you have, the smaller your idle jetting will need to be, since the fuel metered by the jet actually stays vaporized, it's not puddling and condensing. Main jet. 125 primary. 180-190 secondary (not a misprint). I've even seen some engines need 210 secondary mains. If you do not stagger your secondary jetting, you WILL have the same problem of severe lean out when the secondary opens up, since airspeed drops so much due to air flowing thru 2 bbls. You want to be lean on the primary (for mpg and cool running), but richen up to 13:1 when the secondary opens. Most clowns jet the primary and secondary the same. So when airspeed drops to <1/2 when the secondary opens, the vac signal the main circuit sees is also < halved, and your pride and joy leans out like crazy. This is why the secondary main MUST be much larger than the primary main. I'd like to slap the morons that recommends square jetting on the main jets. They are clueless. Air jets. 160-180 will work, I generally use 160 on primary, and 180 on secondary. If you use a 180 secondary air, you may need to go up 10 more on the main, to a 190-200 secondary main. Do NOT be scared of the "huge" secondary jet, it WILL WORK PROPERLY. I've setup hundreds of these carbs, and know what works and why. If you are at elevation, for every 4k' drop both idles 5 drop both mains 5 increase airs 10-15. These guidelines will work for a heated intake, properly setup carb (float, fuel pressure), with no ignition "issues". Sea Level, run 45/60, 125/190, 160/180 @4-5K', run 45/55, 120/180, 175/190 @8k', run 40/55, 115/175, 190/205. I even saw one guy at 8'k that needed a 37.5 primary idle. If you do not have the intake heated, your jetting will have to be much richer than this, for reasons mentioned previously. These guidelines are not exact, but VERY close. I hope this helps. E-mail me directly (please do NOT use PMs, I do not check these) and I'll help further. Please have the basics covered first (fuel pressure, floats, ignition, etc), because that's the first thing I'm going to address, and if you do not I cannot help you. John Aircooled.Net Inc. http://datsun1200.com/modules/mediawiki ... adjustment http://www.webercarbsdirect.com/v/vspfi ... 0Guide.pdf http://vw.zenseeker.net/WeberProgressive.htm http://www.racetep.com/weberX.html |
| Author: | Bones_99 [ Wed Sep 08, 2010 9:10 am ] |
Perrib Thats some good info. I have read a few other places that said that empi's are a pita. I might try and get this thing to work for now but will replace it soon. I am not going to dump money in this carb if I am going to replace it. Thanks. |
| Author: | perrib [ Wed Sep 08, 2010 10:56 am ] |
There is a lot of stuff there. A long time ago I had to learn about them with only CB's book and experimenting to find what worked best. I agree about not spending any money on a T-1 with a progressive. But any carb/carbs you buy will require another investment for fine tuning unless you are very very lucky. |
