HELP Motor isnt running like it should!
http://woodsbuggy.com/phpBB3/viewtopic.php?f=3&t=10168
Author:  jayrod [ Sun Aug 29, 2010 3:16 pm ]
Post subject:  HELP Motor isnt running like it should!
Alright , so my motor was rebuilt again, and first off it wouldnt start because friend who built it didnt time it right, so after i figured that out and readjusted all the valves, instead of the rotor on the distbtr pointing towards the alternator or in the general area It points towards the #4 cylinder when the everything is set TDC on the compression stroke like it should, I got the motor to run but its rough and sounds like a knocking or pinging. I spun the distrbtr so that #1 was lined up with the rotor when tdc But soething is up i pulled the spark plugs and they are black as night and covered in carbon or soot what ever you wanna call it. Could it be the distributor drive shaft in wrong causing the whole problem? Im lost on this one and ill never let another person work on anything of mine ever again. atleast if i had put it together i would know where i may have screwed up ANy help is greatly appreciated
Author:  jayrod [ Sun Aug 29, 2010 3:42 pm ]
Post subject:  Re: HELP Motor isnt running like it should!
Another thing is the motor sounds nothing like it did before the rod bearing went out 2months ago, everything is the same just new crank and bearings for everything So why would the exhaust sound seem so different, this thing is defnitly got something wrong Im just stumped
Author:  ironhorse [ Sun Aug 29, 2010 4:08 pm ]
the motor will run with the dist. turned 180 degrees out like you said it was it sounds like to me you could have bad valve ping try adjusting the timing and see if that helps
Author:  jayrod [ Sun Aug 29, 2010 4:24 pm ]
Ive done everything possible took it all apart well valve train and dist. assebly put it all back together myself and readjusted everything and its perfect now. Thanks for answering though. Idk what it was but its fixed, I knew it wasnt running right but i was told o no ur just hearin stuff cuz u blew the other motor up and ur paranoid, HAHA Maybe paranoid cuz someone else put it together this time! :mrgreen: SO IM good to go now.
Author:  woogiebugger1 [ Sun Aug 29, 2010 5:10 pm ]
As te old saying goe's, if you want something done right, do it yourself. You obviously were smart enough to get it right. Patience my friend, Patience. Good things take time. Enjoy your success, and take pride in your accomplishment!!!!!!
Author:  jayrod [ Sun Aug 29, 2010 5:15 pm ]
lol. Well said. Cant wait for wellsville this weekend should just leave 2moro im not workin anyways haha The wifey might not like that though
