It is currently Mon May 04, 2026 7:39 pm
 Post subject: clean case
PostPosted: Thu Aug 05, 2010 9:55 pm
What is the best way to clean the inside n outside the case want to po,ish the outside want to do this in the garageof
if you cant duck it fudge it
 Post subject: Re: clean case
PostPosted: Thu Aug 05, 2010 10:01 pm
spray degreaser on it then take it to a car wash and power spray it.
PostPosted: Thu Aug 05, 2010 10:05 pm
already done still very dirty
PostPosted: Thu Aug 05, 2010 10:24 pm
i just use castrol super clean and a brush . wear rubber glove cause it will dry your hands out really bad.
