 Post subject: welding a cracked case
PostPosted: Tue Aug 03, 2010 12:07 pm
I have a 8" crack in the top of my AS21 2332 case. The case had a 6" crack last season and I tried to fix it with JBweld and now it's 8" starting above #1 and traveling down the side towards the cylinder. The case is on its last leg and I'm just trying to finish the season. Has anyone tried durafix on a mag case?
PostPosted: Tue Aug 03, 2010 12:21 pm
That case is definatly on its last leg. I am surprised that it has not gernated the way you drive. When you fixed it last year did you drill a small hole at the ends of the crack to stop the continuation of it?
PostPosted: Tue Aug 03, 2010 2:42 pm
try some devcon epoxy it is much better than JB anything
PostPosted: Tue Aug 03, 2010 8:39 pm
Can you get someone to TIG weld it for you. The rod is a bit expensive but you should be able to save the case.
PostPosted: Tue Aug 03, 2010 10:43 pm
Seriously devcon? devcon? You trying to starve me hahaha.
Ive got the good stuff(BELZONA) if you want to try it. In fact ill walk you through the steps and give you the literature on how to fix it( we have a written procedure for this).
Chris im curious as to where you work to have experience with devcon. I am a belzona rep for the northwest alabama area... pm me if you want....
PostPosted: Tue Aug 03, 2010 10:49 pm
Also, I want to add that you have to terminate the crack in order to stop it. Find a small small drill bit and drill a hole at each end of the crack. Depending on how big you may way to take some metal screw and screw them in the crack to give it ridgitythen saw the heads and the screw inside the case off. After that you need to roughen the outside of the crack up as much as possible( i use a 16 grit aluminum oxide disc). *critical* you then need to either sweat the case to remove as much oil as possible. If you use our 1831 product it will work with oil present but i still suggest sweating the cracked area out. I then would wipe with mek and apply product with a reinforcing cloth..... Feel free to ask questions this is what I do for a living...
PostPosted: Tue Aug 03, 2010 11:12 pm
didnt know u sold belzona, i have heard it was good stuff too, just never had any to try
i used to work at wolverine tube in decatur till they shut down and we had the devcon in the tool crib and have used it and have noticed it at a few parts stores here lately but i wouldnt mind trying out some of the belzona next time i need something like that
PostPosted: Tue Aug 03, 2010 11:19 pm
Just let me know. I keep a "trial" supply at the house. Its fixed quite a few tractor blocks,weedeaters,pressure washer pumps, tractor tires, etc haha....
I bet you worked with my uncle Mike Berryman(blue) and my girlfriends dad Mark Retherford(sweet roll)...
PostPosted: Tue Aug 03, 2010 11:30 pm
yep worked with both of them in same department and same shift most of the time and as a matter of fact roll's wife amanda is my cousin
PostPosted: Tue Aug 03, 2010 11:35 pm
There's alot of Google stuff about welding vw blocks.
PostPosted: Wed Aug 04, 2010 12:17 am
Small world... I live down the road from roll's house and mike pretty much lives in my back yard....
PostPosted: Wed Aug 04, 2010 10:18 am
I've done some mag welding, and the filler rod is expensive!! The welding shop I go to gave me about 10 peices. Its really no harder to tig than aluminum, and the best fix I'm sure. if you lived a little closer, i'd weld it up for a case of beer! :mrgreen:
PostPosted: Thu Aug 05, 2010 10:57 pm
Ok thanks guys. I’ve decided to try durafix it should be here Monday. The case isn’t really worth much. It has 15 thousandths endplay and up and down movement. This is just to try to finish the season. I will try to take video using the durafix and post the results.
Here is a video of the crack. Its not that great because I was trying to hold a flashlight, my cell phone and rev up the motor.
This is durafix
PostPosted: Thu Aug 05, 2010 11:22 pm
that stuffs pretty cool just hope it work as easy for you as it does for him. :shock: good luck when you going wellsville again?
PostPosted: Fri Aug 06, 2010 6:24 am
i seen that stuff on tv if you act now they will dubble the order is it still $19.95 :lol: when you get it i have to see it. it looks to good to be true let me know how it works
PostPosted: Fri Aug 06, 2010 7:44 pm
I was talking to a guy I work with, and he said that when he was at the Canfield Swap Meet, a guy was there selling that rod and demonstrating it. He was welding on pop cans, and it welded just as easy as it was in the video. I asked him how much he was selling it for. He said that he wasn't interesting in welding pop cans, so he didn't ask the guy. I really did see the stuff on TV, and I forgot how much the stuff went for. What did you end up paying for it? Hope it works for you.
PostPosted: Sat Aug 07, 2010 3:03 pm
$40 shipped for 1 pound of it.
PostPosted: Sun Aug 08, 2010 9:17 am
So did the aluminum solder work? Just so you know, there is no penatration when using this and is similar to putting bondo on a car fender.
PostPosted: Sun Aug 08, 2010 4:33 pm
I know that you're trying to finish the season, but I would'nt take the chance ruining the engine internals just to ride it out for the season, there is a lot of riding left to do especially into the middle of December. I would go ahead and find me a case and get it ready for the 2276 parts and then take a couple of weekends to covert everything over to the new case. I learned this the hard way 4 years ago.
PostPosted: Sun Aug 08, 2010 5:40 pm
I'm with you Chad. When parts exit the block unexpected it always cost more :roll:
PostPosted: Sun Aug 08, 2010 9:10 pm
PostPosted: Sun Aug 15, 2010 2:48 pm
My crack
PostPosted: Sun Aug 15, 2010 4:51 pm
hillaholic wrote:
My crack
....................is this where we post the crack jokes?................
- Sigmund Freud
- Antonio Meloni
PostPosted: Mon Aug 16, 2010 8:24 am
did the repair fail and the crack get worse?
PostPosted: Mon Aug 16, 2010 3:41 pm
That alm welding rods shit is just that .
