It is currently Sun May 03, 2026 5:03 pm
Post new topic Reply to topic  [ 80 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Thu Apr 12, 2012 7:38 pm
With a good tight deck and a nice open chamber like your heads now have, you will have absolutely no problem running 9.5 on premium pump gas. Keep the timing in check. I would say 28-30 degrees total advance. As for the torque specs, I go to 30 ft. lbs on the big main studs, 15 ft lbs on the small perimiter nuts and 23 ft lbs on the head studs.
PostPosted: Thu Apr 12, 2012 11:13 pm
OK... trying to figure out what spacer I need now... want to end up somewhere between .045 and .040 (sound right?). So far every combination I have for spacers is no good... I go from .035 to like .056... and larger...
Anyone know if I can buy spacers or shims closer to me? (Lou/IN area)... Otherwise I will need to order... looking to pick up a set of .060 and a set of .020... I am pretty sure those will get me what I need with a mix of what I have... I have a .055 that with the .020 might do it (.046) or I think the .060 with my .010 (.009 actually) will get me .040.
wish I could just pick up what I needed local...
thoughts?
PostPosted: Fri Apr 13, 2012 9:43 pm
OK, I think I have my numbers... I will just need to order the spacer. Note the size of the spacer was what my meter showed... guessing it was 75 and 65 though...
1
2 ( .074 gave .045 deck) (.064 gave .035)
3
4 ( .074 gave .050 deck) (.064 gave .040)
So now before I order (I hope this is the last time). Do I want to run .040 or .045?
78mm forged crank
CB perf. H beams
94mm mahle pistons
This case will be decked in the future so its equal or I will replace it one... but for now I am going to need dif numbers to get what I want.
And to be clear, I quit trying to measure each side of the piston pin and now I only measure into the hole they have on the deck height tool where the screw was.
thoughts?
PostPosted: Sat Apr 14, 2012 8:19 am
I posted the same question on onther form and they are telling me I will have detination with that compression with the size cam I have... :( is that true... or was he saying detination with that cam if I run pump gas and high compression? I need to get past this part... so many people have dif. opinions on this subject... its driving me nuts.
78mm stroke
98mm bore
w110 cam
Head CC 56
.040 = 9.6
.045 = 9.5
.050 = 9.4
.055 = 9.2
.060 = 9.1
.065 = 9.0
Thoughts?
PostPosted: Sat Apr 14, 2012 2:46 pm
If your concerned about it just set it up at .050 and be done. I just finished an engine pretty much identical to yours and it was 9.4:1 with a cam very similar to a 110. Keep a good tune on it and keep the timing in check,you will be fine. If your still worried add some good octane booster or mix a gallon of race fuel per tank.
PostPosted: Sat Apr 14, 2012 4:00 pm
X2
PostPosted: Sat Apr 14, 2012 4:03 pm
Brians Off Roud is south of Inde 317-840-7507
PostPosted: Sat Apr 14, 2012 4:21 pm
78mm stroke
98mm bore
w110 cam
Head CC 56
.040 = 9.6
.045 = 9.5
.050 = 9.4
.055 = 9.2
.060 = 9.1
.065 = 9.0
I need 98mm bore on my eng.
Thoughts?
PostPosted: Sat Apr 14, 2012 5:51 pm
thanks guys... I will shoot for .040 and see how it runs... I dont mind getting a tank of race gass and adding a mix if needed... as long as I can get it in under 050 I think I will be fine... but shooting for .040-.045
appreciate the feedback...
Aaron, so you ended up with an .048ish deck to get that compression? Should I just shoot for anything under 50?
Now where do you think I should get the spacers?
#2 ( .074 gave .045 deck) (.064 gave .035) (guessing .070 will be .040)
#4 ( .074 gave .050 deck) (.064 gave .040) (guessing .070 will be .045)
seems like most .060 are closer to .055 or so... I need to go out and mic out my stack of colected spacers agn...
PostPosted: Sun Apr 15, 2012 1:04 pm
I don't like to build them with anything over .055 total deck,including copper head gaskets if they are used. Personally I would set yours up at .045-.050.
PostPosted: Sun Apr 15, 2012 1:39 pm
thanks... that will be my goal...
question.
my case is not decked so I am off by like .010 from side to side (1&2 - 3&4) so what if I can get say .045 on 3&4 side but I end up with .047 on the 1&2 side... Is that OK?
I ask because with the goof ball spacers I can find (without getting a custom set) are going to be a tiny bit off... I need .080 and .070 to get .045 on each side (+or-)... but the spacers measure like so:
.060 = .062
.080 = .078
.020 = .020 (so I am told)
I have .055's and .010's, .098, .090, .092 (few more sets...) I plan to use the .060 (or .062) and my .010 with the .080 (or .078) to get the deck... but due to the measurements it will be a tad off.
thanks for your thoughts...
PostPosted: Fri Apr 27, 2012 3:19 pm
OK guys, I finally got the new spacers...
After I had time to try to set the deck I learned 2 things...
1. my mic I am using is junk
2. this is a pain in my ass
but really... after checking the shim and seeing they were all slightly different in size the closest I can get to an even deck is as follows:
1 and 2 (.088) gives me a .052 DH
3 and 4 (.078) gives me a .049 DH
might be a bit closer but looks like it will fall into the .050 DH range. which still gives me 9.4.1 compression... that should be good for high octane pump gas I think.
I am going to mic the sob agn tomorrow and will do so until I am 10000% sure of the exact numbers... then I think I will call it a day... as long as I end up .050 or less (I know it’s not exact, but I don’t think many are) I will be fine... I will have the case decked over the winter and make sure I can set it to an even tighter deck height after I have some case work done.
you guys think I will be good set up this way? thanks for your thoughts...
Also should my w110 be OK for 9.5 compression range? looking on the site they say 8.5.1 max...
PostPosted: Sat Apr 28, 2012 7:18 pm
With your heads ported it will run Good and make good TQ and HP to 5500. I would run 1.25 or 1.3 rockers .
PostPosted: Sat Apr 28, 2012 8:28 pm
thanks for hanging in there for me man... I ended up with an .049 deck... not to bad... I have CYL 3&4 on right now with the head snugged up waiting for the threebond to tack up good before I torque it down... nice to see the heads going back on... wish I could buy you guys all a beer for the help... beed several years since I have torn one of these appart... just want it to turn out well...
Off to get the other side on and call it a night...
PostPosted: Sun Apr 29, 2012 4:01 pm
It is difficult to get them all exactly the same unless you cut the piston tops. .003" isn't gonna make a bit of difference. Good luck, its gonna be a whole new animal now!
PostPosted: Sun Apr 29, 2012 6:56 pm
I have a set of solid shafts should I just get the rocker arms for them? if so which ones (brand wise)... Looks like CB Perf. sells the 1.25 rockers... I am looking to see what I can find...
I have an adjustable pushrod one the way and have a set of Chromalloy pushrods that I can cut to length as well.
this is next on my list for the motor.
PostPosted: Mon Apr 30, 2012 6:14 pm
I see CB Performance has a set of 1.25 rocker arms for 157 (super stock rockers) they also have nicer ones for like 240.00. Also I see Scat and Empi sell a 125.00 version as well.
any thoughts...
PostPosted: Mon Apr 30, 2012 7:37 pm
I like the wons with lash caps like Scat racing forged or pauters rockers. But i have seen all the otheres work.
PostPosted: Mon Apr 30, 2012 8:20 pm
Cant you add the lash caps to any set of rocker arms? I am looking for a deal... Dont mind used from a good source. My pushrod tool is on the way... Just need the rockers.
I see the scats and empi and others... but only new sets with lash caps (250ish)...
Example:
1.25 High Ratio Rocker arms Price: $125
Empi high lift ratio 1.25 rocker arms with bushing.made from forged chromoly, strongest rocker arms available... $125.00 shipped
Or
VW Performance Rockers 1.25 Or 1.4 $ 129.oo Price: 129
RIMCO PERFORMANCE ROCKERS
SOLID SHAFTS, HARDENED ADJ. NUTS/SCREW, CHROMOLY ROCKER STUDS
AVAILABLE IN 1.25 AND 1.4
PRICE : $ 129.oo
Or
NEW Scat 1:25:1 Ratio Rockers Price: $129.95
BRAND NEW
Scat Pro Street 707 1.25:1 Rocker Arm Assemblies
1.25 Ratio Rocker Arms are Made By SCAT From 4140 Chromoly
Kits includes: Forged Rocker Arms, Billet Rocker Shaft Kit, Mounting Blocks, Swivel Adjusting Screws Geometry Pads and Shims
Shipping to anywhere in USA: $12.50
but I bet I should be able to locate some used ones for not much more that are better?
PostPosted: Tue May 01, 2012 12:46 am
You should be looking for the rockers that have the adjuster on the pushrod end of the rocker arm. The stock style 1.25's work fine but they are a pain in the ass and take some work to get the geometry right with swivel feet in them.
PostPosted: Tue May 01, 2012 6:46 pm
I see these out there:
New Scat rocker sets, 1.25 Price: $239.99
I like the CB performance product better I think but its a 1.3... I have read some things that tell me that 1.3 may be to hard on the valves...
Are these the rockers you guys were talking about?
PostPosted: Fri May 04, 2012 10:10 am
I took a chance.. a set of the Scat 1.25 rockers from samba... I hope it works out ok...
http://www.thesamba.com/vw/classifieds/ ... id=1301133
scat 1.25 ratio rockers Price: 120
Look like the pro street rockers to me... they sell for like 250.00
I think My next post will be in another thread... this one is getting long... will start something off for rocker geomitry...
thanks guys...
PostPosted: Fri May 04, 2012 5:05 pm
Thats the wons you wont. Early scats 1.25 will do 1.25 to 1.3 .You will have aroud .490 to .509 lift. You have dual spring right.
PostPosted: Fri May 04, 2012 6:00 pm
yup, dual springs...
PostPosted: Fri May 04, 2012 7:54 pm
Nice score! They look brand new. Did you get the lash caps as well?
