It is currently Sun May 03, 2026 11:23 am
Post new topic Reply to topic  [ 35 posts ]  Go to page Previous  1, 2
PostPosted: Sat Feb 09, 2013 7:23 pm
what clutch are you running
PostPosted: Sun Feb 10, 2013 11:51 am
Roy wrote:
Great job on the motor build. I knew you would be happy with the combination.
What did you set your cam timing to? Did you zero it? I didn't know you were going to run 11.5-1. Wow is right!
Keep good fuel in it and you should be fine. Hope you have a good transaxle! :)
Didn't we discuss 11.5-1 ? thought that was what you said would yield another like 30 hp lol And its running on straight Cam 2 ,timing is about 30 at the moment. Yea I used the zero washers.
"IT IS WHAT IT IS"
PostPosted: Sun Feb 10, 2013 11:56 am
Ive got a Kennedy stage 1 pressure plate, with a stock disc from Jims
"IT IS WHAT IT IS"
PostPosted: Sun Feb 10, 2013 12:18 pm
you have a lot of power now you will need a stage 2. did you buy a pressure plate or you using your old one
PostPosted: Sun Feb 10, 2013 6:18 pm
I bought it last year, but yea using the "old" one
"IT IS WHAT IT IS"
PostPosted: Sun Feb 10, 2013 6:49 pm
ive always run a stage 1 kennedy plate with a 4 puck disk w/ springs in it.. never has givin any trouble, no slip all grip :mrgreen: and have a few buddies that use stage 1 plate w/ kush loc disk and that combo works good too 8)
LEGALIZE BLUEGRASS!!!
Save a tree... eat a Beaver
PostPosted: Sun Feb 10, 2013 7:19 pm
My plan was to order a kush lock and swap it out when the new one I have in there gives me trouble.
"IT IS WHAT IT IS"
PostPosted: Sun Feb 10, 2013 7:30 pm
that sounds like a plan that way you will find out if a stage 1 is heavy enough for you.Im running a stage 2 with a kushloc and had good luck with it
PostPosted: Tue Feb 12, 2013 8:37 pm
Yes I remember now...........man it sucks to get old. :|
PostPosted: Tue Feb 12, 2013 8:53 pm
Lol, thanks again for all the advice an direction to go with this build.
"IT IS WHAT IT IS"
