It is currently Tue May 05, 2026 2:52 am
Post new topic Reply to topic  [ 28 posts ]  Go to page Previous  1, 2
 Post subject: Re: 1915 HP guess
PostPosted: Sun Jan 27, 2013 6:17 pm
MadMike wrote:
This is for an engine dyno, or gross HP? Well, subtract 30% off what the engine dyno says and that's what is hitting the ground, or net hp. 100 crank HP is only 70 HP at the ground, which isn't much. :lol: :lol: :lol: :oops:
SAE Net hp is measured at the engine's crankshaft, and so does not account for transmission losses
Travis
PostPosted: Sun Jan 27, 2013 6:27 pm
I pulled the end castings off today they were already ported so I put on a set of aftermarket ported end castings. It made nearly the same numbers up to 6000rpm but was down about 4-5% after that all the way to 7400rpm were it made 78hp didn't try the 1-5/8" but did a compression test and 1 cyl was down 30#.
Travis
PostPosted: Wed Jan 30, 2013 7:03 pm
2800passat wrote:
Gaining 1/5th cc and claiming 1/2 more hp (60+30) or nearly double ? Even with all the tricks,factory engineers German or Jap that season a motor and put the right size ports , valves, cam, balancing etc and us rednecks just call California and listen to all their verbage and throw unbalanced chineese stuff in a case and expect results that they can't match.I'd guess at 80-85. and that is over a 1/3 more hp from the original 60.)
So. After all the factors and the calculating and de calculating was I the closest?lol
