It is currently Mon May 04, 2026 3:16 am
Post new topic Reply to topic  [ 29 posts ]  Go to page Previous  1, 2
PostPosted: Mon Aug 16, 2010 8:08 pm
I pissed a guy off at the webster flee market once, who was trying to sell that junk.
PostPosted: Tue Aug 17, 2010 10:50 pm
My buddy is going to tig weld it for me. This is an AS21 case. Will aluminum rod work on it or do I need magnesium rod? I called a few local welding shops and they don’t stock magnesium rod. My buddy said aluminum should work but want to ask the experts.
BTW I couldn’t even get the case hot enough to flow the durafix shit. I did map gas for 20min in one spot and it just wouldn’t flow.
PostPosted: Tue Aug 17, 2010 11:03 pm
You will have to use mag rods. I tried to weld a mag piece on a partner saw once and just about burnt the damn thing up. Mag. makes its own oxgen thats why they stoped making mag wheels when a car would catch on fire they couldnt put the wheels out. Anyway i wouldnt use aluminum rod on it. And if your not sure if it is mag or alum. just pour a little bit of vinegar on it if it fizzes up it mag. if it does nothing it alum. Good luck.
PostPosted: Wed Aug 18, 2010 5:46 pm
Mag rod aluminum will not work it will look ok but will not burn in & stick . Call drews for mag rod
