 Post subject: Pushrod tubes???
PostPosted: Thu Mar 11, 2010 12:40 pm
Will spring loaded pushrod tubes for a type 1 engine fit a type 2 engine???
What do you all think about spring loaded tubes?
Thanks
MoblMec
Tim
 Post subject: Re: Pushrod tubes???
PostPosted: Thu Mar 11, 2010 1:27 pm
yES, bUT THE ONLY TIME i WOULD USE THE SPRING-LOADED TUBE IS FOR A TRAIL FIX.
PostPosted: Thu Mar 11, 2010 1:46 pm
Spring loaded tubes dont seal well & a small stick can dislodge one. I like stock crush tubes or double jam nut tubes myself. Those take a beating.
PostPosted: Thu Mar 11, 2010 2:30 pm
I have use the crush-type ones and the spring-loaded ones, to me, it seems like the spring loaded ones does a better job than the crush ones, I think the crush-type ones will not expand and retract with the engine, the spring-loaded ones will, the brand that I am using are Jaycee ones and they have a larger bore and double o-rings and they run around $90 for a set, I was constantly having oil leaks from the crush tubes and have to keep turning the tubes to seat them in better, so I went away with them and got the Jaycee ones, you don't want to run the plastic tubes, they are JUNK and they will break too easy from what I heard. The Jaycee are very nice heavy-duty aluminum tubes and you can get them in almost any color anodized. This is my $0.02, maybe it does better or not, maybe I'm just lucky :mrgreen:
PostPosted: Thu Mar 11, 2010 11:06 pm
T-1 and T-2 pushrod tubes are different.
