It is currently Mon May 04, 2026 11:30 am
PostPosted: Tue Nov 24, 2009 5:17 am
ive found a 2276 engine kit for bout $$950.00 shipped to me you all think thats a pretty good deal? heres what it has in it i mean is this all the good stuff? my old original motor that came in my buggy was done in mahle stuff but what in the heck is BVW some cheap shit?
Mahle 90.5mm/94mm Pistons and Cylinders Kit
- BVW Chromoly Gland Nut
- BVW 78mm/82mm Forged Counter-Weight Crank
- BVW 5.4" Forged I-Beam Connection Rods with ARP 8740 Bolts
- Engle W120 Performance Cam
- BVW Heavy Duty Lifters
- CB Performance 3/8"/0.058" Chromoly Pushrods
- Elring German/American Gasket Kit
- Schadek 26mm or 30mm Oil Pump
- Mahle Main Bearings
- Mahle Rod Bearings
- Mahle Double Thrust Cam Bearing
Brandon
PostPosted: Tue Nov 24, 2009 10:35 am
sounds like a good price,but u need to carry ur block to a machine shop and let them do ur main bearings
PostPosted: Tue Nov 24, 2009 4:36 pm
not sure what the bvw is but i think you would like the 110 cam with 1.25 rockers better than the 120 cam from all the questions ive asked and researched and just like chris said you need the line bore and thrust checked on your block before putting it all together and the block will also need to be clearanced the the stoker crank also but think the cam will clear in a 2276 without any clearanceing
PostPosted: Tue Nov 24, 2009 10:31 pm
What is bvw ?
PostPosted: Tue Nov 24, 2009 11:28 pm
not sure myself ive been in buggys over a year and still aint never herd of BVW thats why im tryin 2 figure it out
Brandon
PostPosted: Tue Nov 24, 2009 11:42 pm
110 cam 1.25 rockers h beams..
"buy the best, cry once"
PostPosted: Thu Dec 10, 2009 10:54 am
whats the good brand? not lookin to buy the cheap stuff but not the highest either
Brandon
PostPosted: Thu Dec 10, 2009 8:32 pm
I like cbperformance or Scat. I have personally been disappointed with the quality of EMPI.
Many people like EMPI but I am staying away from them.
PostPosted: Thu Dec 10, 2009 10:06 pm
Call Drews at 1-888-go-drews 110 engle cam scat light weight lub a lifters scat 1.25 racing rockers .& dual valva springs ?
PostPosted: Thu Dec 10, 2009 11:15 pm
You live in KY,buy your stuff from Tim at Southern buggys.
PostPosted: Fri Dec 11, 2009 12:40 am
got that right!
tim is THE MAN hes helped me out a bunch when i first got my buggy hes always had anything ive needed or wanted 8)
Brandon
PostPosted: Fri Dec 11, 2009 12:45 am
i like empi myself too!
all my stuff ive bought thats that brand has worked good for me but i aint bought any motor parts thats empi other than the plastic push rod tubes <come to think of it now im not even sure if them tubes were EMPI but i think they was
Brandon
PostPosted: Fri Dec 11, 2009 12:48 am
Most things EMPI are poop anymore.
PostPosted: Fri Dec 11, 2009 1:07 am
truthfully i aint bought any empi stuff in quite some time right at a year or so id say they was a pain to get them tubes in there when i aint done it before but my cv joints seem to be holdin' up good :wink:
Brandon
PostPosted: Fri Dec 11, 2009 1:13 am
i totally agree with both of these statements
PostPosted: Fri Dec 11, 2009 1:25 am
European
Monkey
Poo
Inbreeding
PostPosted: Fri Dec 11, 2009 1:56 am
hillaholic wrote:
European
Monkey
Poo
Inbreeding
my first motor that came in my buggy was done in mahle it was a pretty good motor till the cam cracked the block............ :roll:
Brandon
PostPosted: Fri Dec 11, 2009 9:42 pm
BY from all the sponsors . I like engle cams & the good scat lub a lifteres & rockers . Souther buggyes with do You right.
