It is currently Tue May 05, 2026 12:24 am
PostPosted: Sun Nov 15, 2009 9:10 pm
Well, if I want to offset grind the stock crank that I have, could I weld( with a regular welder) the outside of the journals and then go to the machine shop and regrind the crank to stock rods?? The price of a 74mm crank is a little to high for me(I'm cheap) so could this be or am I way off base?? Thanks Dave ( doing an upright conversion)T
PostPosted: Sun Nov 15, 2009 9:36 pm
Most shops like to grind to a smaller journal . But some will weld & grind . I dont no of a shop that will grind after some body welds by hand They have a machine
PostPosted: Mon Nov 16, 2009 6:43 am
Thanks, I'll check around and see. Didn't know if that was how it was done or not. Thanks Dave T
