It is currently Mon May 04, 2026 9:41 pm
 Post subject: Tru Cool Oil Coolers
PostPosted: Sun Sep 13, 2009 11:36 am
Any have any good luck out of the Tru Cool coolers? They work pretty well? Now that I have been running across the sand alot I need a better cooling system. I'm thinking about running twin 72 Plates with twin fans. I couldn't find one big solid one. I thought I would ask if they were worth the money before I buy.
I'd buy two good working used ones if anyone has any forsale.
Thanks for info guys!
Boyd Jordan
 Post subject: Re: Tru Cool Oil Coolers
PostPosted: Sun Sep 13, 2009 4:03 pm
They look like the Borg /Beck Mesa oil coolers that you can stand on. Care must be taken to hold the ends securely when taking fittings on and off. I use them on all my stuff.
PostPosted: Sun Sep 13, 2009 4:49 pm
They come with pull fans right? Hold up well to weather? Electrical wise...
You run the long or short little rubber mounting studs for the fan?
Boyd Jordan
PostPosted: Fri Oct 16, 2009 10:42 am
I've had one for 7 years with no issues, I use a toggle switch and a temp gauge to decide when to turn it on. How hot is your oil? Two coolers sounds like over kill..
PostPosted: Fri Oct 16, 2009 1:04 pm
I did this on my turbo buggy, 2-92 plate mesa coolers and a DTM fanshroud. Oil temp would barely reach 120*. I do believe that optimum oil temp is around 180*. Once I deleted the 2 mesa's my temp went up to that range. Just my experience.
PostPosted: Fri Oct 16, 2009 4:34 pm
How hot is it getting Boyd?
Gotta get up to a minimum of 180° to burn off the condensation in the oil.
Like Dave said, two plate coolers can be overkill.
