It is currently Mon May 04, 2026 3:49 pm
 Post subject: Blown oil galley plug
PostPosted: Wed Dec 03, 2008 10:02 pm
A freinds motor blew 1 of the larger oil galley plugs out the back of the case,has anyone seen this and what size drill bit and tap would i need to fix it.
PostPosted: Thu Dec 04, 2008 9:58 am
Here is some info on you request, but I don't know what size you will need depending on how large the hole is.
NPT National Pipe Thread
Tap size. Threads per inch. Drill size.
1/8 - 27 - 11/32
1/4 - 18 - 7/16
3/8 - 18 - 19/32
1/2 - 14 - 23/32
3/4 - 14 - 15/16
1 - 11-1/2 - 1-5/32
PostPosted: Thu Dec 04, 2008 12:04 pm
Best if you use a tapered reamer along with that tap drill.
3/8" NPT is the most common plug for the bigger galley.
Here is a good site for some pointers on galley plugs.
http://www.huelsmann.us/bugman/FilterTech.html
PostPosted: Thu Dec 04, 2008 6:56 pm
That site and chart is a big help,thanks alot Gary.
