It is currently Mon May 04, 2026 3:48 pm
 Post subject: 1600 questions
PostPosted: Mon Nov 24, 2008 6:16 pm
ok i have a brand new 1600 but it wontrun right on certain day it runs awsome but on other day it wont run worth anything any ideas
 Post subject: Re: 1600 questions
PostPosted: Mon Nov 24, 2008 6:29 pm
Stock carb and intake?
What exhaust?
PostPosted: Mon Nov 24, 2008 6:40 pm
it has a solex and it has a tepee header
PostPosted: Mon Nov 24, 2008 7:17 pm
My guess is the intake is freezing up.
Pretty common on a center mount carb/intake if you don't have any heat.
Run crappy when it's cold-get better when it warms up?
PostPosted: Mon Nov 24, 2008 9:05 pm
Could be borderline rich/lean when it is running "right" and when the weather changes it is showing up as a symptom. :?:
Aut Viam Invenium Aut Faciam!
PostPosted: Tue Nov 25, 2008 1:36 pm
it does good when it warms up but it wont run long enough to warm up it will stall out and act like it floods it self really bad
PostPosted: Wed Nov 26, 2008 12:14 pm
I've never messed with solex carbs any but it sounds like the choke pull off may be sticking. My old Chevy does the same thing in cool weather for a few minutes, you have to keep it running by holding the throttle open a little until the choke pull off finally kicks in, then it runs perfect. Never been a problem for me cause I hardly ever drive it and never remember it when I'm not driving it so it hasn't been fixed.
PostPosted: Wed Nov 26, 2008 2:19 pm
when I had a solex on my bug I had problems with the choke. It would do the same, run good one day run like crap another. try tying the choke open once it's running and see what happens. I went too a progressive 2bl.
PostPosted: Wed Nov 26, 2008 4:02 pm
im redoin the frame this winter its a rebel bobtail im think on a dolrto when im extending it and put a irs torshin in so i can really ride ill try vthat if it dont work trash cannin that slowlex
PostPosted: Thu Nov 27, 2008 11:43 pm
I had almost the same problem on my solex it was the linkage for the accelarator pump. It has a small ball and clip that holds it in place if the ball is worn the linkage can shift and starve you of fuel to the point of not running but for a second.
WHEN IN DOUBT DRINK ANOTHER BEER!!!!!!!!!!
