It is currently Mon May 04, 2026 3:48 pm
PostPosted: Sat Nov 15, 2008 12:50 pm
Image Is this it ive got a as-41 that has been done like that on my buggy that 2276 case isnt just wandering if ther is any differance between the 2 so i can make the mexico case full flow???? and what i need to do besides just drilln it if any thing ????? :? :?
Lets Ride!!!
PostPosted: Sat Nov 15, 2008 4:31 pm
Thats the right port it needs drilled to 37/64 and taped to 3/8 pipe. The top of the port is thin I had to weld the top of mine to keep it from cracking. The hole needs drilled off set down a little. I like to tap the port going from the oil pump to the one you drilled 1/4 and plug so you dont got to plug the pump.
Travis
