It is currently Mon May 04, 2026 1:33 am
 Post subject: 1641 help
PostPosted: Fri Sep 05, 2008 11:08 pm
haveing prolbems put new points in and plugs ranfine went to leve for work started spitting and spudring and died toed home and re set teh points ranfine a bout 20 mintes then died now it runs fine for aubout 5m then dies
 Post subject: Re: 1641 help
PostPosted: Fri Sep 05, 2008 11:12 pm
Did you replace the condensor also? Also coils start failing after they get hot. Just a couple things to check.
Woody
PostPosted: Fri Sep 05, 2008 11:23 pm
okthanks
PostPosted: Sat Sep 06, 2008 12:57 am
Is it still pumpin fuel thru the squirters after it dies? When I was a kid I had a street beetle with a rusty tank that would run until the fuel filter would get clogged up, then it would quit. After the junk in the filter settled, it would run fine again for a few minutes.
Larry
PostPosted: Sat Sep 06, 2008 1:10 pm
dont no what to do put goodcoile and condseron ran fine fora bout 15m thenstarted siptting andspottering amd died no wont stay runng
PostPosted: Sun Sep 07, 2008 6:03 pm
This may sound silly, but you might check your fuel lines for strength, I have had instances where and old fuel line, after it gets warm might collapse and that would shut fuel off to your engine.
If its got boobs or a motor its gonna give you trouble!!
PostPosted: Wed Sep 10, 2008 2:16 pm
The key to figuring this out is to check to see if it is getting fuel or spark when this happens. Find out which one is missing then we can go from there.
PostPosted: Sat Sep 13, 2008 11:13 pm
found that coile was bad put 1 on and sofar sogoodand rew set points runs good
