It is currently Mon May 04, 2026 1:32 am
 Post subject: 6lb flywheel
PostPosted: Wed Jul 09, 2008 9:50 pm
I found this in the attic of my shop. I used to run it on a buggy with a 1775. I took it out because the brads that hold the center in worked lose. I took it to the clutch shop and had it rebuilt, now I'm thinking of putting it in my stroker motor. Has anyone ran a flywheel that light in a big motor? It worked great in the small engine....super quick revs.....you could let out and bring it back on hills. Anybody?
Life is short.....Play Hard!
 Post subject: Re: 6lb flywheel
PostPosted: Thu Jul 10, 2008 6:18 pm
6lb? 8lb works good!
PostPosted: Thu Jul 10, 2008 6:28 pm
i know dean is running some retardedly light flywheel...
PostPosted: Thu Jul 10, 2008 6:41 pm
and he is still not as cool as i lol
PostPosted: Fri Jul 11, 2008 7:27 am
I didn't know if this would work with a big motor. I do know these are hard to come by because they were discontinued many years ago.I'm going to try it....I'll post the results. Thanks
PostPosted: Fri Jul 11, 2008 8:44 am
When you go to put it on make sure you put the flywheel holder on the thicker parts of the flywheel holder or it will bend.
cyle
PostPosted: Fri Jul 11, 2008 4:17 pm
Hill Climber
I can hook you up with one. A 6 lb steel flywheel. I love mine.
Harry S. Truman
PostPosted: Sun Jul 13, 2008 11:57 pm
Is it that weight originally or has it been cut down? I've never seen a steel one that light.
