It is currently Mon May 04, 2026 1:33 am
 Post subject: Spark Plug Gap
PostPosted: Thu May 15, 2008 11:29 pm
I have a 2276 with dual dell 45's and i was wondering how do you determine what the spark plug gap is? I set mine to 25 I was told the smaller the gap, the hotter it is, is this true? Also, what brand is a good brand? I have been running NGK's any input would be appreciated.
 Post subject: Re: Spark Plug Gap
PostPosted: Thu May 15, 2008 11:53 pm
NGKS ARE GOOD FOR HIGH RPM MOTORS AND I KNOW THE GAP IS DIFF.IF U HAVE MSD CALL TIM HE KNOWS BOTH 606-864-2217
PostPosted: Fri May 16, 2008 4:34 am
The spark plug gap is based on the compression ratio of the motor, the octane of the fuel, the type of plug and the energy of your ignition system.
PostPosted: Fri May 16, 2008 7:28 pm
i got a chevrolet HEI distributor,they recomend .045 thous.
PostPosted: Sun May 18, 2008 12:00 pm
denzo plugs. i can get a plug number if you want. they are the best
PostPosted: Sun May 18, 2008 1:13 pm
Do you run 14mm or 12mm plugs? I run 12mm plugs and used to run Denso Iridium IX27's and switched to Champions and notice a difference in performance (cheaper plugs=more power) I done some homework myself and it works for me. Denso are good plugs too, but I figured if I try to change plugs just for the heck of it and to see if there are any difference in performance because I was trying to tune in the engine and I guess I found my problem by accident, so I ran Champions since. There are other people that are running them too and they say they are better ones. Just my two cents.
PostPosted: Sat Jun 07, 2008 9:10 am
what kind of chevy hei distributor are you runnin? what did it come out of?
PostPosted: Sat Jun 07, 2008 8:20 pm
performance distrubtor in memphis builds them for VWs,i really like them u can but rev limiter in the dist.and built in coil
PostPosted: Sun Jun 08, 2008 8:02 am
ok i was wonderin cause i put a cavalier dist in mine this weekend it took some modification but i like it better than points
