It is currently Mon May 04, 2026 1:34 am
PostPosted: Sun Jun 01, 2008 6:12 pm
I need to know how far the back wheel should stick out from the tree bar.I know it is a little bit,but just want to make sure it is not to far.I took a straight edge across the back tire and i have 2.5 in. to the tip of the tree bar.Could some of you measure yours and let me know what yours is.I have a Beeline Cobra frame with firestones.
PostPosted: Sun Jun 01, 2008 6:24 pm
mine are 1.5 in. past my tires
PostPosted: Sun Jun 01, 2008 10:26 pm
buckmaster we made mine stick out past the tire about a 1/2 inch. just make sure the tire is not exposed at all ask DVS1 about that :shock:
"Lets go get stupid"
PostPosted: Mon Jun 02, 2008 3:15 pm
Mine stick out 1/2 inch past the tire. Don't get them to close to the tire or the tire will rub it when it is in full compression. Tack it on then get 5 of your buddies to bounce it hard to compress the suspension all the way to check for clearance.
PostPosted: Mon Jun 02, 2008 4:22 pm
Mine are about two inches from being as wide as the tires......... :?
That way when I bought the buggy.
I need to put weld some spurs on and all would be good then.......... 8)
PostPosted: Mon Jun 02, 2008 4:36 pm
All the info you guys gave me sounds good,i just misunderstood when i was talking to a friend.Thanks for the help. :D
PostPosted: Tue Jun 03, 2008 12:34 pm
Site Admin
Thats a bad memory I try to forget.
