It is currently Sun May 03, 2026 1:51 am
 Post subject: 1600 VW FLYWHEEL
PostPosted: Sun Oct 11, 2015 5:14 pm
I have a 1600 Air Cooled VW Motor that I have been working on for a long time now. I have a Counterbalanced 8 Doweled Crank I bought in 1999. The project been put on hold for 15 years or so. My question is the 8 Dowel Flywheel that I bought in 2015 doesn't seem to fit. It measures like it should, but it doesn't slide on like I thought it would. I don't want to force anything, but it should fit regardless if they are bought 16 years apart. Or should they.?
 Post subject: Re: 1600 VW FLYWHEEL
PostPosted: Sun Oct 11, 2015 9:13 pm
They should be the same, nothing has changed that I know of. Remember there is a dowel that is offset ,so the flywheel will only go one in one position
PostPosted: Sun Oct 11, 2015 10:08 pm
Thanks for the info helmetguy I did not know that. This is my first flywheel
The offset must be minor because I kinda thought about that and looked for it and didn't see anything obvious. Is it Marked somewhere?
PostPosted: Mon Oct 12, 2015 7:49 am
No its not marked , but yes difference is pretty small. For me its easier to see on the flywheel. Make sure you set your end play correctly, I think its .002-.006
PostPosted: Mon Oct 12, 2015 9:38 am
Thanks, it's tight but slid right on.
