It is currently Sun May 03, 2026 4:11 am
 Post subject: OIL PRESSURE
PostPosted: Thu Apr 24, 2014 9:10 pm
Just built a 2332 Full Flowed with remote filter and oil cooler, oil pressure is out of sight. Keeps blowing the O-ring out [/color]of a FRAM PH8a or busting a line, finding a weak place. I checked my short relief spring and went back with a OEM spring, no change. Anyone have any suggestions? I plan on finding the HP1 filter but, it will not correct my problem I don't think.......SUGGESTIONS PLEASE!!!!!!!
 Post subject: Re: OIL PRESSURE
PostPosted: Thu Apr 24, 2014 9:34 pm
linezs to remote filter hooked up backerds?
PostPosted: Thu Apr 24, 2014 9:36 pm
do you have the remote filter that bolts to the oil pump itself?
PostPosted: Thu Apr 24, 2014 10:00 pm
High oil pressure on a fresh rebuild in not uncommon. You "must" use an HP filter and good quality lines. You will need to let it warm up for a bit before giving it RPM. What weight oil are you using? Possible you may need to switch to thinner viscosity until the motor breaks in some.
PostPosted: Thu Apr 24, 2014 10:41 pm
Make sure the relief piston isn't stuck in the bore. What size oil pump? What weight oil? Throw the POS Fram filter as far as you can and get a quality filter like a mobil 1 or wix. Also as previously stated,check to make sure all oil lines are hooked up correctly.
PostPosted: Fri Apr 25, 2014 8:24 am
The 2332 in my woods buggy has a melling pump, full flow, remote filter and cooler and accumulator. If i dont let it warm up for about 5 mins (when its warm outside) it will blow something every time. I have blown apart coolers, filters and autometer guages if I rev it up with out warming.
PostPosted: Fri Apr 25, 2014 8:20 pm
if all else fails you can put a thicker gasket on your oil pump cover. you would be surprised how much that changes oil pressure.
PostPosted: Sat Apr 26, 2014 8:24 am
To small of oil lines will do it to. Use at least 1/2 id lines.
