It is currently Sun May 03, 2026 4:12 am
 Post subject: 1641 questions
PostPosted: Sat Mar 08, 2014 8:42 am
IM in the process of building a 1641 for my buggy as just a temporary motor. I bought 87mm slip ins, has 043 casting heads that I did a mild port job on along with the intake manifolds, my question is there a kit so I can run an oil filter instead of that strainer and what kinda power am I making now? Like I said mild port job all around, a 3 angle valve job and 87mm slip ins, everything else is stock
If the women don't find you handsome, they should at least find you handy -Red Green
 Post subject: Re: 1641 questions
PostPosted: Sat Mar 08, 2014 4:51 pm
PostPosted: Sat Mar 08, 2014 5:40 pm
What ^ said lol
Sent from my iPhone
PostPosted: Sat Mar 08, 2014 7:24 pm
You can run this style, not the best but better than the screen.
http://www2.cip1.com/ProductDetails.asp ... C-C10-5384
run this style but you have to full flow the case.
http://www2.cip1.com/ProductDetails.asp ... -C10-5386E
run this pump with an inlet and outlet with an oil filter adapter.
http://www2.cip1.com/ProductDetails.asp ... 26-115-165
These are Cip1 products, good for a temp motor.
Hope this helps..
PostPosted: Fri Mar 28, 2014 10:29 am
Any idea what my compression ratio is? If it helps my head castings are 043's and I polished the combustion chambers but really didn't remove any metal
PostPosted: Fri Mar 28, 2014 11:03 am
PostPosted: Fri Mar 28, 2014 12:07 pm
and don't forget to tap the shaft thru the oil pump gear til it meets the cam..
PostPosted: Sat Mar 29, 2014 6:24 am
To find compression ratio you need to CC your heads and find out what your deck height is. then you will know your true CR. http://www.aircooledtech.com/deck_height/
PostPosted: Tue Apr 01, 2014 8:42 am
So if my compression ratio is 8.2:1 would I still be ok running 87 octane?
PostPosted: Sun Apr 06, 2014 8:01 pm
If your CR is in the 8's , I would run mid grade or super if it was mine. 87 octane would be ok if you were in the 7's. Gas is really poor these days. Your antique air cooled engine craves octane. The slower burning fuel really does help it out when the motor is at full operatring temperature. If it was my engine, I would set the CR into the low 9 range and run 93 octane. Why not get the max power out of it when you are setting it up from scratch anyways? That's just me though. If it was a street driven car, it would be a different story.
PostPosted: Wed Apr 09, 2014 1:56 am
anything under 10 i believe you can run pump gas
