It is currently Sun May 03, 2026 3:33 pm
PostPosted: Thu Nov 07, 2013 10:21 pm
Was going to start gasket matching my intake manifolds today and found another reason to not buy empi shit. Put my gasket up to the manifold to draw the line and found a serious casting shift problem. The intake ports are off center about a quarter inch. Anyone around Columbus have a tig welder to fill these in a little bit so I can match them to the heads?
PostPosted: Thu Nov 07, 2013 11:01 pm
Why not just open the heads to match instead of trying to weld the port in the intakes up?
PostPosted: Thu Nov 07, 2013 11:07 pm
I don't plan on keeping these carbs forever I eventually plan on moving up to Weber 40's. I don't want to match $800 dollars worth of heads to these kadrons.
PostPosted: Thu Nov 07, 2013 11:20 pm
In that case just match them as good as possible and run it.
PostPosted: Thu Nov 07, 2013 11:21 pm
I'm 1st in line to hate empi. I watched a tv show on Why do Chinese build crap. A foreigner walks up to a Chinese businessman and says , here build this to these specs so I can save mega $. i.e. an EMPI rod. He out sources it to a dozen mom n pop shops. Wong Wun does not buy the right steel alloy grade. Wong Way may have a lathe that ain't true. Long ding Dong does not do a pressure test on alllll of them. Yer motor slings a part. Rod goes thru block. Does Mr. Empi buy us new C.B. heads, blocks new oil, gaskets etc etc? Is Mr. Empi there to pull you out of the woods and put you back on the trailer? Stop eating out of Empi's hands. Passat eats out of junk yards looking for old German quality. Does it climb? Ask the witnesses. E.M.P.I. Every Motor Part is _______ .fill in the blank.
PostPosted: Thu Nov 07, 2013 11:24 pm
Every Mistake Passes Inspection
PostPosted: Fri Nov 08, 2013 8:10 am
LMAO... Loving the names...
PostPosted: Fri Nov 08, 2013 10:35 am
That is definitely there slogan
PostPosted: Mon Nov 11, 2013 8:53 pm
I would re-locate the two bolt holes as far as I could first. In fact I would build up the outside of the flange to move the bolt holes where they need to be before I would weld up the runner.
PostPosted: Mon Nov 11, 2013 9:49 pm
Id send the junk back with a letter on why before i did anything just my 2 cents
PostPosted: Mon Nov 11, 2013 10:08 pm
Just hogg'em out and let it go
PostPosted: Mon Nov 11, 2013 10:19 pm
I would send them back except I picked these up at a swap meet.
PostPosted: Mon Nov 11, 2013 10:23 pm
Hogging them out would require hogging and my heads too. I'm a little Leary on masacuring a set of $800 heads. I swallowed my pride and realized this is above my talent and equipment level I dropped them off at a welding shop today. Thanks to the guys that offered there help but this welding shop charged me less than what it would take to ship/drive these things back and forth.
PostPosted: Tue Nov 12, 2013 12:06 am
Mr Empi will stand behind it. He'll stand behind your butt!
PostPosted: Tue Nov 12, 2013 12:15 am
If I was Mr Empi i would stand behind something too with all the people who wants to throw their parts at him hope he knows how to duck
PostPosted: Fri Nov 15, 2013 8:16 pm
Problem solved.
PostPosted: Tue Nov 19, 2013 8:54 am
looks good, its a shame when you spend your hard earned money on thier product you have to do their leg work.
PostPosted: Mon Jan 20, 2014 9:15 pm
The peg that goes into the cam slot from the EMPI oil pump broke therefore no oil and a galded up crank and block. Chinese cheese!
