It is currently Sun May 03, 2026 8:34 pm
 Post subject: fire problem
PostPosted: Wed Jan 30, 2013 2:38 am
having a problem getting fire ok first off it all started when i blew my eletronic ignition so at first i was gonna just swap the whole distributor so pulled it out but decided to just go on and replace the ignition so put it all back in so now its probably all off time i have never messed with a distributor anyway now im still not getting any fire to the plugs could that be cause its so off time or would it still have fire even if it was when i put it in i set it to top dead and slid it in and it went in correct and tightened it all down or is the only possibility that my new ignition was bad im lost on this one also i know the coil is putting out spark
 Post subject: Re: fire problem
PostPosted: Wed Jan 30, 2013 2:59 am
if it was out of time u would still have spark. do u have a resister between the coil and distributer? is it gettin good ground from the coil to the dis? is ur rotor button burnt or any burn spots in the cap??
PostPosted: Wed Jan 30, 2013 3:08 am
button is good cap is good nothing between the coil and dis and good connection from coil to dis i cant figure it out :evil:
PostPosted: Wed Jan 30, 2013 3:11 am
maybe u did get a faulty igntion i run electronic also with a generator so i run a resister
PostPosted: Wed Jan 30, 2013 3:16 am
well im gonna put points in it tomorrow to test so that will tell me if its the ignition
PostPosted: Wed Jan 30, 2013 12:12 pm
1st guess, have someone witness that the dist is spinning.try to bypass key switch?
PostPosted: Thu Jan 31, 2013 1:00 am
did not get to mess with it tonight will update tomorrow after i try points
PostPosted: Thu Jan 31, 2013 5:23 am
volt meter n test light... dont put points in if u never fooled with a dist.. go on n put back another elec ign,,
the women r at the top of the hill
PostPosted: Sat Feb 02, 2013 8:01 pm
Got it running coil was bad must have fried it when it got the ignition
