It is currently Sun May 03, 2026 2:10 pm
PostPosted: Sat Apr 28, 2012 10:08 pm
I finally got a few minutes to look at the buggy today. Everything looked fine except cylinders 1 and 2 are not firing.
I have not even began to troubleshoot it but I thought it would be fun to let everyone take a guess at the problem.
Buggy fired right up.. Was running rough, so I went back and checked the headers. Cylinders 1 and 2 were cold. Cylinders 3 and 4 were hot.
Lets here your guesses...
PostPosted: Sat Apr 28, 2012 10:26 pm
Broken valve springs would be my first guess ,thats what we ran into tonight try to get a buggy ready for this weekend .
PostPosted: Sat Apr 28, 2012 10:29 pm
Dirt in the carburetor.
PostPosted: Sat Apr 28, 2012 10:30 pm
Bad intake leak
PostPosted: Sat Apr 28, 2012 11:50 pm
be positive cylinders 1 and 2 are still on the buggy may be why they not working :mrgreen:
PostPosted: Sun Apr 29, 2012 7:55 am
crossed plug wires on 1 and 2.
air leak on 1 and 2
tight valves
bad pick up in the distributor
fouled plugs
bad out of sink carbs
clogged carbs
bad plug wires
cracked distr cap
PostPosted: Sun Apr 29, 2012 10:12 am
air leak on 1 and 2
tight valves
fouled plugs
clogged carbs
bad plug wires
cracked distr cap
Pick one......contest rules suck
PostPosted: Sun Apr 29, 2012 10:19 am
Firebug wrote:
air leak on 1 and 2
tight valves
fouled plugs
clogged carbs
bad plug wires
cracked distr cap
Ok dang it. im gunna say electronic ignition went bad.
PostPosted: Sun Apr 29, 2012 10:35 am
fouled plugs...
PostPosted: Sun Apr 29, 2012 11:08 am
first thing to check would be wether or not your gettin spark. if so then check fuel, then suspect valve train issues. atleast thats my order of elimination. :mrgreen:
"IT IS WHAT IT IS"
PostPosted: Sun Apr 29, 2012 3:54 pm
Radiator leak, or bad ECU
PostPosted: Sun Apr 29, 2012 4:01 pm
just went out to work on mine, and cylinder 1 was dead. been trying to figure it out, now 4 is down also? im confused. distributor?
"IT IS WHAT IT IS"
PostPosted: Sun Apr 29, 2012 8:56 pm
Now that is some funny stuff.. I just laughed out loud and my kid wants me to explain why it is funny..
PostPosted: Sun Apr 29, 2012 9:07 pm
Firebug wrote:
Bad intake leak
Marty wins troubleshooting bragging rights... That makes two Bragging Rights Contests for Marty..
Although, I could have saved a lot of time if I would trouble shoot in a different order..
Pulled the Valve covers and checked the rockers and rods.... Everything looks good
Pulled the plugs and checked for spark... Everything looks good
Checked the cylinders for compression ... Everything looks good
Cleaned the jets in the carb... Everything look good
Hmmmmm... I have spark, fuel and compression.... Hmmmm
Grabbed a can of starter fluid, started the buggy and sprayed the intake manifold.. Found the problem..
I have a crack in the rubber boot on the intake manifold.. Fortunately, it is something easy to fix..
PostPosted: Sun Apr 29, 2012 9:29 pm
Dangit I never win ....... :cry:
PostPosted: Sun Apr 29, 2012 9:44 pm
MM you cheated, I thought you had dual carbs. :lol: :lol: :lol: :lol: :lol: :lol:
PostPosted: Mon Apr 30, 2012 6:48 am
I remembered seeing Kevin and Bebo find that same problem on a buggy at Lock 17 a couple years back.
