| Should I cut my boggers??? http://woodsbuggy.com/phpBB3/viewtopic.php?f=29&t=9649 |
| Author: | A. Cole [ Mon Jun 07, 2010 10:15 pm ] |
| Post subject: | Should I cut my boggers??? |
I have 33x10.50 boggers, they hook good (well fling alot of s@#$). Will I sacrifice my axles, cv, tranny to take the small lugs off? I'm not a primary hill climber, lets face it I have a non stroker 4 seater with heavy (but nice) coilovers. The more traction the better but I don't want to replace parts every weekend. |
| Author: | Odyknuck [ Tue Jun 08, 2010 8:41 am ] |
| Post subject: | Re: Should I cut my boggers??? |
I have not run uncut Boggers so I have no empircal data to pull from. However they are a very stiff tire and do not flex with out at least cutting some meat off between the lugs and sidewalls. I will also say that they are a very heavy tire and removeing the little lugs and additional meat will make them lighter and less burdon on the drive train and of cource give you a lot better performance. Every pound you are rotating equates to 50 pounds of spinning mass. If your happy with the way they perform then leave them alone. |
| Author: | RaceBugg1098 [ Tue Jun 08, 2010 11:57 am ] |
Cut 'em and let er eat!! I broke plenty of stuff without cutting them so dont fool yourself into thinking it really make a difference on how safe your trans is. |
| Author: | hyde [ Tue Jun 08, 2010 6:53 pm ] |
CUT & cut |
| Author: | nitro_mudder [ Tue Jun 08, 2010 7:25 pm ] |
Cutting tires Pro's and cons. Pro's 1 Less weight means less stress on Drive train 2 Less weight means less strain on your engine 3 Cut tires will flex and get better traction 4 Cutting small lugs off will remove weight and make larger cleanouts for better traction. Con's 1 Cut boggers will not be street legal. 2 Small lugs cut off will increase the chance of ripping off a large lug. 3 ?????? ok I don't have a third. |
| Author: | A. Cole [ Tue Jun 08, 2010 9:38 pm ] |
I had a feeling thats the response I was going to get... I might do a little trimming, Its hard to cut up new tires. I think I was always going to cut them but I needed a little peir pressure/support |
| Author: | aboone993 [ Tue Jun 08, 2010 10:04 pm ] |
I have never known anybody that cut their tires and said they wish they hadn't ! SO GET AFTER IT !!! |
| Author: | nitro_mudder [ Tue Jun 08, 2010 10:10 pm ] |
aboone993 wrote: I have never known anybody that cut their tires and said they wish they hadn't ! SO GET AFTER IT !!! I disagree, not because of the tires. Because of the work and knotted up forearm, lol. |
| Author: | Odyknuck [ Wed Jun 09, 2010 8:57 am ] |
nitro_mudder wrote: aboone993 wrote: I have never known anybody that cut their tires and said they wish they hadn't ! SO GET AFTER IT !!! I disagree, not because of the tires. Because of the work and knotted up forearm, lol. I guess you will have to lift some more weights! |
| Author: | nitro_mudder [ Wed Jun 09, 2010 9:55 am ] |
Haha, very funny. I just have KOKO cut them |
| Author: | dirtdobber [ Wed Jun 09, 2010 1:27 pm ] |
stanley 1 inch .25 clear handle wood chisel works very easy. Needs to be on rim with air in it. |
| Author: | Maddog [ Wed Jun 09, 2010 11:24 pm ] |
I don't think koko wants to cut anymore boggers after he cut firebugs. |
| Author: | hayshaker247 [ Mon Jun 21, 2010 6:53 pm ] |
nitro_mudder wrote: Cutting tires Pro's and cons. Con's 1 Cut boggers will not be street legal. 2 Small lugs cut off will increase the chance of ripping off a large lug. 3 ?????? ok I don't have a third. i have ran cut boggers on the street and been pulled over for speeding in a jeep and the only thing the cop asked was if they were DOT approved he saw it on the sidewall and i went about my way.. and they were on 32 bolt beadlocks "told him they were fake locks lol" |
