It is currently Sun May 03, 2026 5:30 am
 Post subject: 14mm wheel studs
PostPosted: Mon Jun 01, 2009 5:31 pm
Anyone got a place I can order new 14mmx1.5 wheel studs. Threaded on both sides
 Post subject: Re: 14mm wheel studs
PostPosted: Mon Jun 01, 2009 8:59 pm
are you using the same rotors as me?
"IT IS WHAT IT IS"
PostPosted: Tue Jun 02, 2009 12:06 am
I would use press in studs. I've seen one to many wheels come of from them.
PostPosted: Tue Jun 02, 2009 8:10 am
ive lost a wheel in a bad spot due to those studs. press in only!!!!!
PostPosted: Tue Jun 02, 2009 9:24 am
press in or through bolts! i ripped off both wheels at once with those. and i have a stock motor. unless you lug around and NEVER get on it. then you can use them. press in's!
P.S. STOP LUGGING AROUND!!!!!!!!!!!!!!!!!!!! :lol:
PostPosted: Tue Jun 02, 2009 9:57 am
Franken, it was just a test run, lol. I hit it hard enough to ride a wheelie the 2nd time.
PostPosted: Wed Jun 03, 2009 11:58 pm
yeah...... wellll. My motor in 30 years old, and it went up that! :D haha
PostPosted: Tue Jun 09, 2009 10:37 am
Well I can't find press grade 8 14mmx1.5 thru bolts, damnit! So I guess I will have to drill it out to, ummm , who knows what size for press-ins?
PostPosted: Tue Jun 09, 2009 11:25 am
Summit Racing and ebay offer a lot of different sizes including the Knurl diameter.
PostPosted: Thu Jun 11, 2009 6:47 pm
i have used grade 8 bolts with threads all the ways to the heads and screwed them in from behind. you can get those from fastenall
PostPosted: Thu Jun 11, 2009 7:44 pm
i'm still running lug bolts i just bought some a little longer and they work fine.yes they are harder to put the wheel on,and yes i do curse sometimes,but it gives you more time to drink a beer when your working on it and we all know that is very important.when you can make more time for beer i say do it.lol.chad :mrgreen:
PostPosted: Thu Jun 11, 2009 11:34 pm
Wife said she wasnt going with me this weekend chad. So I panicked, who was going to hold my whiskey!!! So I rushed out and got a cup holder, ziptied it to the frame. THEN, she decides shes coming, lol. Did I just hijack my own thread? I found 1/2" press ins that fit in the 9/16ths hole I spent $20 on a bit to make. The darn 14mm press ins wernt long enough. Just needed to replace one for now, bandaid fix till I find a heavier one I like.
PostPosted: Fri Jun 12, 2009 6:32 am
same here. you will have to grind the heads round to clear the bonnet of the rotor. Then cut a slot in the stud/bolt for a screwdriver also locktite them in..
PostPosted: Fri Jun 12, 2009 1:13 pm
I was going to go with bolts. But couldn't find em grade 8 full thread 14mmx1.5, Fastenall couldn't get em.
PostPosted: Sat Jun 13, 2009 3:12 am
I get them from my bolt supplier I only have 2left I'll call mon and get more if anyone needs them give me a shout
PostPosted: Mon Jul 13, 2009 2:15 am
I have these again there 14mm x1.5x50mm just screw them in from the back side of hub with red lock tight and your good to go! 1.95ea
PostPosted: Wed Dec 09, 2009 11:14 am
CHECK OUT SPEEDWAY MOTORS. GREAT SELECTION, GOOD PRICE, TO YOUR DOOR IN A DAY OR 2. CHECK OUT THE LUG NUTS TOO. TAPERED ON BOTH ENDS.
PostPosted: Fri Dec 11, 2009 6:36 pm
Fastenal should get just about anything you need when it comes to bolts. The way that I understand grade 8 metric bolts, they are labeled as "8.8" on top of the bolts. I put my rotors on a milling machine and programmed in the bolt circle and made the holes a little bigger to use 5/8" press-in, fine-threaded chromoly studs I got from my local race car shop and they are awesome, I even use the same thing on my adapters as well but coarse threads on them, it takes a 1" socket to fit the lug nuts and they are chromoly too. I personally don't like using bolts because they will come loose over the time of riding before you know and it is a pain in the a$$ when you need to tightened them up in the woods, I used to have them on my old Packrat and hates the idea and wishes I never done them that way, do the right thing and use press-ins, they will never come loose unless torqued properly.
PostPosted: Fri Dec 11, 2009 8:16 pm
try late model dodge truck,whould have saved myself serious money after ordering new ones extra long.then bought some 1/2 20 race studs and oversize nuts for adapters ,half the cost of metric and easy to replace.richard
PostPosted: Sun Feb 28, 2010 8:25 pm
Got these still?
PostPosted: Mon Mar 01, 2010 1:49 am
nitro_mudder wrote:
Got these still?
Sure,,,how many do you need?
PostPosted: Tue Mar 02, 2010 8:15 pm
ive got some i think that was in my old rotors u can have them if i still got em
Brandon
