PostPosted: Thu Dec 03, 2009 3:40 pm
Hi Guys
It looks like I might have a choice of what type of wheels and hubs to go with.
What do you all think is the best??? Wide 5, regular 5, or regular 4????? Wheel adapters or not???
MoblMec
PostPosted: Thu Dec 03, 2009 5:28 pm
regular 4 hole disc brake hubs with wide 5 wheels with adapters
PostPosted: Thu Dec 03, 2009 9:22 pm
What is the benefit of using a 4 hole disc with adapters? I would think a regular vw 5 lug would be optimal for both wheels and discs. There are several wheels and disc brake kits available for 5 lug. I have a real hard time finding stuff for the 4 lug.
PostPosted: Thu Dec 03, 2009 9:28 pm
i dont run vw wide 5 i run dirt track wide 5,,, 90% of the guys on here use late model wheels,dirt track wheels are cheaper if u find them used
PostPosted: Thu Dec 03, 2009 9:34 pm
The strongest in order, Dirt track wide 5, VW wide 5, standard Chevy or Ford 5 bolt, VW 4 bolt.
PostPosted: Thu Dec 03, 2009 9:49 pm
so you have the stock rotors drilled for the bolt pattern that you would want ? im askin because i beleive theres a swap meet coming up in massillion and id like to look for a set of the dirt track wheels ! also you guys no what to expect a machine shop to charge to redrill bolt pattern ?
PostPosted: Thu Dec 03, 2009 10:00 pm
Just get a set of wide five rims and get Russ[Instigator] to make you a set of adapters
PostPosted: Thu Dec 03, 2009 10:05 pm
rock , are you saying the dirt wheels bolt pattern are to large to drill the rotors is that why you say go adapters ?
PostPosted: Thu Dec 03, 2009 10:51 pm
Both the VW and dirt track wide 5 bolt pattern are to big to be drilled into a standard rotor.
PostPosted: Sat Dec 05, 2009 12:45 am
thanks mike understand now!
